Question about GE Washing Machines
I have a GE Adora front load washer and my detergent drawer is stuck shut. It won't open no more than an inch. Is there a way to remove it w/o breaking the drawer, in order to get the items out of it?
  • Monique Turner Apr 28, 2015
    The pedestal drawer is what I'm referring to.
Try to take the drawer out as far as it goes
and use a mirror {dental and makeup }
or even a camera phone too see inside
you can take the top off
two screws slide of back lift it off
and shine a strong table light into the plastic soup drawer unit
usually transparent
and examine the drawer
a couple of kettles of boiling water will break up any soap etc
other than this its gota be the removable softener tray
so may need cajoled into place
as above use a long flat something
perhaps cut up a plastic tray,, etc...
sometimes you can unclip the front plastic cover
from the internal tray giving you move access
Posted on Apr 28, 2015
    Master:
  • 301 Answers
Sounds like something is block the draw from open all the way.
Try using a metal coat hanger or a paint stir hand from Home depot the very long one.
slide along the open part of the door.
maklean
  • 1665 Answers
SOURCE: detergent dispenser stuck, I think the detergent cup is preventing the drawer from opening
Here there is a user guide and instructions of a similar washer model.
http://www.laundrymanuals.com/manuals/mfg/lg/wm2496h.html
and also all available LG washer manuals to download.
http://www.laundrymanuals.com/manuals/mfg/lg/lg_frontload_washer_product_list.html
Have a look of how top lid is mounted.
Posted on Feb 15, 2008
mumma_1
  • 903 Answers
SOURCE: front load washer leaks from the detergent drawer in the front
try taking the drawer out and clean it thoroughly, including the underside of the drawer, then clean the inside of the machine where the drawer fits into. Sometimes a build up of dertergent can casue this problem
Posted on Dec 28, 2008
SOURCE: Front loading ge washer won't drain?
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
Posted on Jun 04, 2009
SOURCE: front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Posted on Jun 16, 2009
  • 185 Answers
SOURCE: LG Front Loading washer detergent drawer is jammed
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Posted on Aug 25, 2010
How do I get the stuck detergent drawer open?
U see the blue colour softner drawr inside the detergent drawr just push it down after u remove ur drawr it will come easilly
Feb 25, 2015 | LG Tromm Front Load Washer And Dryer Set
What is an E70 error code in a GE Adora Front load washer?
E70 stands for a stuck key. Try unplug for 60 sec. Then try again. If not unplug and try to open and clean buttons of debris
Oct 27, 2013 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Stuck detergent drawer
GOOD LUCK WITH THAT ONE! I RAN INTO THAT ONCE AND ALL I COULD DO WAS SHAKE THE WASHER AND OPEN AND SHUT THE DRAWER AS MUCH AS I COULD UNTILL THE INSERT SETTLED.THERE IS NO WAY AROUND IT.GOOD LUCK
Jan 17, 2010 | LG WM-2277HW Front Load Washer
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
(front load ATF6000ES) is constantly leaking detergent
the loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
46 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
