Question about Car Audio & Video
An aux cord broke on the inside of the aux input, and I'd like to know how to take out the iput Jack and take out the broken piece inside it.
    Master:
  • 301 Answers
Try using a tweeter or a need nose pier.
Posted on Apr 28, 2015
Charger
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
Apr 16, 2014 | Nabi 2
Audio input jack for headphone component broke off need to find new input and how to replace
No way to do that unless you can figure out a way to remove the part. The contacts inside that plug determine where the sound goes. No way to turn it off unless you remove the broken part. If you feel confident enough, remove the back of the TV and remove the broken piece from the jack.
Mar 02, 2014 | LG 32LD350 32 in. LCD TV
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
Headphone jack has a piece of connector stuck in it and it is making my speakers not work how can i fix this problem?
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
Jun 11, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
How to change the auxiliary input on an ion tailgater
Yo. This same thing happened to me. It sounds rudimentary, but I just superglued toothpicks onto the broken ends (obviously being sure not to get glue on the jack itself) and after waiting for them to dry, I just yanked them out by the toothpick. Worked like a charm. Good luck!
Apr 02, 2012 | ION Audio Tailgater Portable PA System...
2008 Nissan altima auxiliary input replacement. The radio is fine but I bent the wire and it bent/broke the auxiliary input. Can I purchase just the input??
Use a drill to remove it. I need to replace my aux input for another reason. I removed a piece out of my headphone jack on my macbook once. I was nervous doing it because I didn't want to puncture anything, or have heat from friction burn any components. Don't let anyone tell you otherwise, it works like a charm. I'm a novice at fixing things, but I bought a drill and the smallest bits I could find. Put the drill on full throttle and went to town. I could feel the slight hole I created in the piece of what used to be a part of headphones. I used a small screw to actually get into that hole and pull the piece out. Returned the drill afterwords too.
Feb 22, 2011 | Car Audio & Video
HELP FINDING THE TYPE OF AUX PART FOR APPLE HI FI!! HELP!!
Fiber optic is the circtuit ribbon cable that attaches jack to main circuit board. Your best chances are to find one on ebay. Or you can always try amazon.com, newegg.com or etech.com
Sep 15, 2009 | Audio Players & Recorders
Aux cable stuck in Aux input
needdle nose plyers or you can use a screw just turn and pull
Jan 25, 2009 | 2007 Nissan Sentra 2.0 SL Sedan
Aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Aug 13, 2008 | Kenwood KDC-MP435U CD Player
Aux. Input Jack
I had the same problem. I opened up the box and used a glue gun to reattach the aux jack from the inside.
Jun 18, 2008 | Bosch PB10-CD Radio/CD Boombox
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
