Question about Minn Kota Deckhand Electric Anchor Lifts Deck Hand 25
While pulling up the anchor my Minn Kota stopped working. Any suggestions to get it going again.
Fuse looks good
SOURCE: minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
Posted on Aug 03, 2008
SOURCE: The Minn Kota trolling motor
Mine did the same thing and i think that it could be the relay under the switch cause i had power when i directly touched both neg. and pos. so i would diffently take a look at that.
Posted on Oct 02, 2008
  • 8 Answers
SOURCE: Minn Kota lower unit leaking.
Man, you have a job ahead of you. First, if the unbreakable shaft is cracked or broken, you will have to replace it, for it will leak into the motor too. If your unit has the sonar sensor in the front and it has had water in it, the unit can corrode severely and need a lot of parts besides seals. The wiring to the sonar runs in a protective shield bonded to the magnet housing and one of the long screws holds it in there. Remember to take the wiring to the sonar out AFTER you remove the big motor feed wires, and replace it BEFORE you reinstall the red and black cables. Some grease seems to ensure the o'rings slide on metal parts during reassembly rather than tear. It's quite a job.
Posted on Nov 28, 2008
  • 10 Answers
SOURCE: Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Posted on May 08, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn Kota deackhand 35 won't lift a 28lb anchor
    How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
    Sep 29, 2015 | Minn Kota Boating
    Pd 55# power to unit but it won't run
    If it makes no noise when you try to run it, then suspect that the motor is damaged or a fuse is blown. If it hums but won't turn the prop, look to the final drive.
    Jul 29, 2014 | Minn Kota 1358719 - 55 Power Drive V2-48"...
    Anchor will not go down but will go up
    I have two deckhand anchor units. I ve tested both on battery, and both went up. I replaced switches, and I get nothing, but I heard a light click coming from unit. Is the motor bad?
    Nov 09, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    Anchor pulls up won't release to go down on either of the two switches
    Im getting power to motor, but can't get it go down. When I hit switch I can hear a clicking sound from the unit
    Nov 05, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    Lookinf for a manual for a minn kota model 55d
    call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn kota trolling motor will turn to the rt. when i push the pedal down to turn to the left it goes half way and stops. the pedal will not go any further
    Check for rocks or debris stuck in the pedal....
    If not then pull the top cover on the motor and look at the pulley cable drum. Here's a schematic:
    Max 55 bowmount
    Best of luck!
    Mike
    Jun 26, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn kota
    Hello bombiegano. I suggest you check you wiring terminals. They could be corroded. If you have good connections next would be fising line, string or weeds jammed in rotor of your prop motor. If these suggestions fail please inform me of Mgrf.,model & serial# & we can repair the unit. Good Fishing.
    Oct 02, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Deckhand Electric Anchor Lifts Deck Hand 25 Logo
    321 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
