Question about Mercury Sable 86-95 R
How do I stop my car from idling high on its own, it will not shift gear
  • 80 Answers
Your IAC motor may be clogged or stuck the, Idle Air Control motor sets the idle speed after the engine has met operating temperature, the IAC motor is usually on the top of the intake plenum, you can take it apart and see if its clogged or not operating
Posted on Apr 28, 2015
  • 43 Answers
First thing I would look for is a broken small vacume hose or a hole in one.... saw one guy use a spray bottle of just water around the hoses and when water was sucked in the RPM changed... Hence you find the broken hose...
What does it mean when the car jerks when you put it into gear?
The car pulls suddenly hard in forward or reverse direction at the moment you change gears.
Jul 03, 2014 | 2007 Pontiac G6
Idles high from first to second gear .
Define idles high like its going high rpms before shifting or the engine itself is high reving if its high rpming when shifting its mostly you tranny going out you can try tranny fix oil I used it on my truck when it had shifting problems and ive had no problems since it takes a few days to work though and if its the motor itself it could be a lot of things but I dont know much of the problem based on what you told us
Mar 10, 2014 | 2004 Hyundai Elantra
Idling high
I would check the engine coolant temperature switch 1st.
Jan 24, 2014 | 2004 Hyundai Santa Fe
Wont shift from nutral in to gear while running
Often, it mean that the clutch stay engage.
Now the question can be, is the idle to high for the clutch to disengage while at idle? you might try to reduce the idle speed by turning eather the nob on carburator or the ajustement on the cable.
then if the idle is very low and the clutch still engage (that is why you can not shift) you migh want to check at the clutch and see if it is not stuck.
Nov 07, 2013 | RTO 125cc Full Size Adult Quad ATV
Run at hight rpm when i put in gear and runs wide open when i go to stop
high rpm when shifting into gear or high rpm at idle email at allactionmaintenance@gmail.com
Apr 04, 2013 | 1999 Saturn SL
ENGINE IDLEING VERY HIGH IN PARK, WHEN IN GEAR TRANS DOSE NOT SHIFT GEARS
sounds like two problems 1 engine can idle high with vaccum leaks or bad idle air control or maf sensor 2 if trans wont shift in to gear fluid first next would be to tcm or wire connection on trans good luck
Dec 30, 2009 | 1993 Chevrolet K1500
Very high idles and drops into gear roughly
possible vacuum leak or bad idle motor
Dec 14, 2008 | 1987 Dodge D150
My car jumps off when i select the D gear is this a major gearbox problem?
sounds more like a high idle problem to me.
Your tranny should have some "floating" when you shift to any gear, but if you are idled up too high then that "floating" disappears and it jumps.
I would check you idle before you think about tranny problems.
Aug 30, 2008 | Renault Le Car Cars & Trucks
Mercury Sable 86-95 R Logo
54 people viewed this question
Top Mercury Car Audio & Video Experts
xxxxxx xxx
richie46
Are you a Mercury Car Audio and Video Expert? Answer questions, earn points and help others
