Question about Faberware Coffee Makers & Espresso Machines
I have a faberware 4 cup perc134DF and it does not seem to get the coffee as hot. Does it need a thermostat?
  • Faberware Master
  • 5,631 Answers
SOURCE: Need measurement guide
We use 'em every sunday at church - 1/2 cup grounds for every 10 cups water. Allowances: finer coffees will use less grounds, and the more you are making, the fewer grounds you need ( or vice versa- the less you are making, you may need to increase grounds a bit, as perk time will be shorter
Posted on Apr 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: question about cuisinart's DCC-1200 1-4 cup mode
The 1-4 cup setting actually loops the water through the heating element twice. It's a good wrokaround for people who like extremely hot coffee, but not for iced coffee fans like me.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
SOURCE: Delivers only small amount of coffee per brewed cup
this is not a scale issue, mine arrived from the factory producing only 6oz of water. way to strong for most. called the factory, scale, scale blah blah blah, vinegar untill we were blue. bored one day took the unit apart. on the right hand side there is some clear tubing which housed a one way valve, took apart and the valve was partally clogged. removed cleaned and reinstalled, this valve works best when not fully" seated" where it belongs so reinstall gently into the hose and leave it alone. I know what your thinking scale, scale scale. wrong. still only made 6 oz cups. there is a timer device on the back wall of the front panel on the right side as you face the unit. it is adhered to the wall with two sided tape. pry it off and on the back low and behold is a timer screw that changes the length of pump run time. turn clockwise with a sharp knife or eyeglass screwdriver and retest. 9oz of water. shame on keurig for not being more responsive to its customers.
Posted on Jan 19, 2009
devilbiss
SOURCE: Faberware fc412
I've had the same problem, I went with a percolator since our water is hard and we calcify the heating element within about a year. Having the FCP-412 stop working has made me angry as well.
1st, I placed an order for a P04-303 thermostat. It seems to be the correct replacement but we'll see. You can find it here: http://www.goodmans.net/get_item_fa-p04-303_farberware-p04-303-thermostat-for-coffemaker-urn.htm
2nd, here is my 1 cent fix. Really, insert a penny under the thermostat. The delay that it takes to additionally heat the penny will increase the duration that the 1000 Watt element is on. You can experiment with other materials just make sure it isn't flammable (it's next to the element) and it is not too insulate (you want the thermostat to open the circuit some time after the start of the heating cycle (3-3:30 minutes).
Good luck. -david
Posted on Feb 14, 2009
devilbiss
SOURCE: 8-cup Farberware electric coffee maker
Hi, I just posted this for the FCP412 model: here it goes again.
Good luck. -david
How hot should the coffee be in a Farberware percolator
It should be about 180 degrees. The percolator should perc about one minute for each cup of coffee. If it stops too soon and the water is not hot, then the thermostat is bad. The thermostat can be replaced.
Feb 06, 2014 | Faberware FCP280 Coffee Maker
Most electronics have a 1 year warranty, if you could find out were it came from you could take it back and get store credit for it. I wish I could help you more, but on this sort of thing I can't imagine there is much you can do other than that.
Aug 25, 2008 | Faberware FCP280 Coffee Maker
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Sep 29, 2012 | Faberware 12-55 Cup Coffee Urn
How many scoops do I use in a Farberware 30 cup coffee maker for 30 cups?
About 3/4 cup of coffee will make 10 cups of strong coffee...
adjust to taste...
heatman101
Feb 23, 2011 | Faberware 12-55 Cup Coffee Urn
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
How much coffee to use for 55 cups
Follow the directions on the brand of coffee you buy. Usually 1/2 cup of coffee for 10 cups. Ex: 2 3/4 cups of coffee for 55 cups. 1 cup for 20 cups. 2 cups for 40 cups. Hope this helps.
Jul 03, 2010 | Faberware 12-55 Cup Coffee Urn
Am looking for an instruction manual for a Faberware 10 cup coffee maker
Hi, Farberware only makes 4-8-12 cup coffee pots and they all use the same manual. I have some. contact me through callahanronald@att.net. Ron
Jan 29, 2010 | Faberware (R) - Black - Ten cup capacity...
Looking for a replacement handle for a FCP412
Go to my eBay auction. look for Farberware coffee pot parts. They are use but you cannot buy a new one (Ron622c) Good luck. bobbyone
Dec 26, 2009 | Faberware FCP412 Coffee Maker
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
Coffee Makers & Espresso Machines Logo
66 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Dael Escher
Level 1 Expert
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
