IVE TRIED ALL THE USUAL: HARD RESTORE, SOFT RESET, V+/PWR, V-/PWR. HELP PLEASE! NEXTBOOK 8P FREEZE DURING RESTORE
DURING RESTORE FROM CHECKING FIRMWARE, WRITING KERNEL, CHECKING KERNEL, WRITING BOOT TO FREEZE ON THE CHECKING BOOT STEP.
    Master:
  • 456 Answers
Have you tried downloading the firmware and re flashing it ? "google "firmware for ( your model number ) download the firmware/install it on a sd card ( or some do it from your laptop depending on tablet ) but you will get instructions with the firmware on how to do it ..hope this helps
Posted on Apr 28, 2015
Tablet freezes
disk cleanup, try that or you can do a restore point back to before it started acting up, hit the tab scan for affected programs that will give you a hint to where something went wrong its usually an update, that you don't need or a program that's not compatible or the wrong cord, sometimes generic cords that are imitation, will throw it in a loop
Jan 28, 2014 | Tablets & eReaders
Comes on white screen then off just for a second
If possible, try to restore the device to the newest firmware on it using your computer using this firmware:
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-18C/Downloads/LCX-18C-Software-Update/
OR
Do a soft reset. This may resolve your issues and will also keep your data on the device.
Do a soft reset by:
1. Having the device already off
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
If neither of those work, try a hard reset. This will however delete all stored data off your device.
To do a hard reset:
1. Have device off
2. Press and hold the ZIN&ZOUT Keys at the same time
If none of these work, contact Lowrance at 1-800-628-4487
Mar 05, 2011 | Lowrance LC X-18c GPS Receiver
Can you fix my low on memory palm centro. It erased all of my photos and won't take new ones. It says momory is too low. Can you fix?
hi,
you have to reset your phone in order to fix that..but you have to save all your important data before you do the reset...here is how..
Performing a soft reset is similar to restarting a computer. If your Centro device is not responding or you're having trouble synchronizing with your computer, a soft reset may
help. All your information is retained when you perform a soft reset.
1. Remove the battery from your device, and then reinsert it.
Note: The reset begins when you insert the battery and ends when the
Date & Time Preferences screen appears.
2. Select Done.
Replacing the Battery
Your Centro device comes with a replaceable battery. Be sure to use a battery that is approved by Sprint and that is compatible with your device. Failure to use the proper
battery may result in personal injury or product damage, and it voids your device warranty.
1. Press Power/End palm_centro_hard_reset_soft_reset_2.jpg to turn off the screen.
2. Gently press down on the Battery Door, and then slide the door downward to remove it from your device.
3. Place a finger in the notch next to the battery and lift the battery up at a 45-degree angle to remove it from the compartment.
4. Align the metal contacts on the new battery with the contacts inside the battery compartment.
5. Insert the new battery into the compartment at a 45-degree angle, pressing it into place. Slide the battery door onto the back of the device until it clicks into place.
6. Connect your device to the charger or sync cable.
7. Wait for your device to turn on, and then enable the network time or set the date and time when prompted.
System Reset
A system reset, also called a safe or warm reset, can be useful if your device loops or freezes during a soft reset. Performing a system reset allows you to get out of the loop and restores limited functionality to your device in order to uninstall a third-party application that's causing the problem. Note that after a system reset, you must perform a soft reset to restore full functionality, including the wireless features, to your device.
1. Remove the battery from your device.
2. Press and hold Up palm_centro_hard_reset_soft_reset_3.jpg on the 5-way palm_centro_hard_reset_soft_reset_4.jpg while reinserting the battery.
3. When Date & Time Preferences appears, release Up palm_centro_hard_reset_soft_reset_3.jpg
4. Delete the third-party application that you suspect is causing the problem.
5. Perform a soft reset. (The wireless features of your device are not available until you complete this step.)
ard Reset
A hard reset erases all information and third-party software on your Centro device. Never perform a hard reset without first trying a soft reset and a system reset. You can restore previously synchronized information the next time you synchronize.
A hard reset can tell you if a problem stems from your Centro device or from an application installed on it. If you do not experience the problem after you perform a hard reset, the problem is related to software you installed.
Important: If you set a password on your device, performing a hard reset reformats your device (the message "Reformatting in progress" is displayed). This is a more severe form of a hard reset, which removes all your information and restores your formats, preferences, and other settings to the factory default settings.
Note: Some third-party applications do not create a backup on your computer when you synchronize. If you perform a hard reset, you may lose data in these applications and you need to reinstall these applications after the hard reset. Please contact the developer to find out which information is backed up during synchronization.
i hope it will help you..thanks for trusting fixya
Jan 31, 2011 | AT&T Palm Centro Cell Phone - White
6300 Nokia. my phone keeps restricting itself. ive had it for over 2years now. is this nokia just trying to get me to buy a new phone?
Try soft reset and see your problem gets solved else go for hard reset
SOFT RESET-*#7380# this will take you to restoring factory
setting.
HARD RESET-*#7370# this will take you to restoring factory setting.Will erase all datas including contacts and memory details.please take back up before you do this..
Jul 24, 2010 | Nokia 6300 Cell Phone
Nokia 6300 security code reset (master code)
imei:353215034660040
i forgot my security code and i want to reset my code so how can i?
Jul 13, 2010 | Nokia 6300 Cellular Phone
Gps module not responding
Hello :
I recommend you to reset your device .
Try this for soft reset :
1. Turn unit OFF
If soft resetting didn't work , then I would recommend you with hard resetting . Here is how to hard reset your device . But Hard Reset (Deletes stored GPS Data such as Waypoints and trails) .
1. Turn unit OFF
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-25c GPS Receiver
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
Can not turn my sony ericsson x1 on. All Isee is
Try reset your phone, if your don't want to lose your data you can use the soft reset or Hard reset to restore to factory default.
This space is too small to explain to you can get a detailed explanation on
http://www.xperiax1.net/forum/xperia-x1/546-tutorial-soft-hard-resets.html
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Feb 10, 2010 | Sony Ericsson XPERIA X1 Smartphone
My ipod wont play
You can always reset your iPod by pressing the home button (middle round button) and the play button. This will soft reset the device.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Apple iPod nano
Sonar Problem
Try a soft reset first, if that doesn't correct it try a hard reset. BE SURE and Save Data before th eHard Reset, it clears all waypoints and such.
Soft Reset Hard Reset
LCX 15mt Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the USA map appears 4. Release both buttons when the USA map appears
Jun 26, 2007 | Lowrance LC X-15MT Sonar
Computers & Internet Logo
David Payne
David Payne
