Question about Dryers
The drum is turning but not heating up why? - Dryers
    Prodigy:
    An expert who has answered 500 questions.
  • Dryers Expert
  • 650 Answers
It could be a bad heater, thermal fuse or if an electric dryer possibly one leg of your power is tripped and needs resetting at the circuit breaker on the house. Try flipping the ganged power breaker both off real hard and flipping them back on real hard and see if that restores the power to the dryer. If a gas dryer then the igniter or flame sensor could be bad.
Posted on May 03, 2015
Why won't it start?
check for the operation of a small micro switch at the door hinge
if that is out of adjustment then the unit will not start
Jan 05, 2016 | Bosch Dryers
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
NO HEAT FRON DRYER , DRUM OK
either your heating element,hi-limit switch,cycling heat switch, thermistor,control panel, or you don't have 240 volts supplying the dryer,120volts will still let the drum turn or the timer count-down, its the way there wired
Nov 01, 2009 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
