Question about 1997 Mercedes-Benz E420 Thermostats 97 Mercedes-Benz Thermostats
Changed Brake light bulbs and the fuse for the brake light but when I step on the brakes the only light that works is the third lite for the brakes
    Sergeant:
  • 313 Answers
Are the bulbs the correct ones for your car. What with the kambus systems in cars now you have to be very careful what you do as it can end up being very costly trying to save money.
Also some bulbs only go in one way.
Posted on Apr 28, 2015
When I start car taillights come on but no brake lights or third light in window
Well your parking lights should not come on when you start the car unless you have turned on light switch. Most cars you must step on the brake to start, so the brake lights would be on. Your problem maybe a burnt out bulb on rear window lite.
TEST: have someone watch the rest and push on brakes see what lights. If 2 tail lite then its blub.
If non light its the fuse in box underdash.
Now take foot off brake and turn on lights and emergency flashers walk around check all lights then step on brake and see if brakes light up.
Replace bulbs or fuses as needed.
Hope this helps Mike
Apr 30, 2017 | Cars & Trucks
Third brake light does not work after changing the bulbs
If some of the lights work then you probably don't need to change the light assembly. My first guess would be a burnt out fuse. Look for the fuse box and remove the cover. Usually on the inside of the cover it will have a diagram for all the fuses and you can find the one for the brake lights. Some vehicles have relays that are fried and these may be under the hood. Just look for a black box which contains electrical relays and other fuses. The last thing I can think of is a switch that is right above the brake pedal. When you apply the brake a small plastic or metal extends and this is what makes your brake light come on. www.lightdeal.co.uk
Jan 29, 2013 | 2007 Honda Ridgeline
Third brake lite [ fused or bulb]
Should be on the same circuit as the regular brake lights.
Dec 07, 2012 | 2004 Chevrolet Malibu Maxx
My additional brake light is not working i have tested the brake unit and that works is there a seperate fuse for this or is it all on one fuse for all the brake lights
The third or High Mounted Brake Light runs straight off the brake light switch on the brake pedal arm. You say you tested the "brake unit"? I assume you mean the third brake light assembly, and if you get power there when someone steps on the brake pedal, then the bulbs are bad.
The power flow for the brake lights goes like this: Fuse ->Brake switch -> Turn signal switch -> Rear lights. The only difference is, if you have a 3rd brake light in your rear window, that gets its power directly from the brake switch. It does not go thru the signal switch first. So, if you are having a brake light problem, and your fuses are good, check the 3rd light in the rear window, if it lights up (assuming the bulbs are good, no one ever changes them), then the problem is most likely in the turn signal switch, hope this helps!
Aug 28, 2011 | 2002 Ford SVT Focus
Brake lights keep blowing a fuse on a 1997 GMC suburban
i have a 95 gmc suburban that keeps blowing the fuse when break is aplied i even disconected the back lights and it does the same what could it be
Dec 21, 2010 | 1997 GMC Suburban
Both main brake lights are out, third brake light works.
Replace the brake light switch located by the brake pedal. That will resolve your problem
Apr 09, 2010 | 2007 Nissan Quest 3.5 Minivan
2000 chevy 3/4 ton diesel no brale light but third brake light wo
I just Know that you replaced the bulb ,try a test lite ,make shure it's grounded well poke inside the socket for the bulb this metal socket gives the bulb both electric and a ground ,this is the problem,good luck.
Nov 14, 2009 | 2000 Chevrolet 2500
Brake lights not working but third brake light works?
Check your fuse for the brakes, if fuse is blown replace. If not fuse go buy a package of brake light bulbs at the auto store. Then replace the bulbs.
Hope this helps
Matt
Jul 02, 2009 | 1999 Ford Expedition
Turn signals work but the brake lights do not how do i get them to work? i already changed the flasher.
I have a 2001 Ford F150, my brake lights dont work. Ive replaced the bulbs, checked the fuses,and the brake switch on side of the brake pedal was replaced. I still dont have any brake lights. My third brake light works fine, along with my running lights,flashers, blinkers.
Jun 18, 2009 | 1985 Ford F150
1997 Mercedes-Benz E420 Thermostats 97 Mercedes-Benz Thermostats Logo
65 people viewed this question
Top Gates Vehicle Parts & Accessories Experts
Lodhi Autos
Lodhi Autos
Walter Turteltaub
Level 1 Expert
Bill Boyd
Are you a Gates Vehicle Part and Accessory Expert? Answer questions, earn points and help others
