Question about Metra 2000 Chevy Tracker/Metro/Prism
Starter wires on a 98 chevy prisam what dose the colors constist of
    Habit-Forming:
  • 83 Answers
The wire is white from the starter key switch which goes through the neutral safety switch and is now black to the starter relay, there are 2 inertia cuto off switches in both drivers and pass kick panels which will disable the starter relay also if activated.
Posted on Apr 28, 2015
  • 63 Answers
Unsure of th colours.
But you should have 2 cables.
He starter takes earth from the casing and engine mount.
You will have a heavy 'red' cable going to one side of the solenoid 12v+
Then you will have a little lighter (smaller gauge) cable that triggers the solenoid.
Why dose my pwr aux fuse keep blowing in 98 Chevy blazzer
you have a short in the wiring have it found don't let it go with out having it fixed
Apr 19, 2016 | Cars & Trucks
98 chevy blazer won't start new fuel pump, new starter, battery good. will not turn over. ignition switch changed. its not getting fire to the starter.
Have you checked the purple wire directly at the starter for power when the key is turned to start? Is the vehicle equipped with any type of remote start or alarm system?
May 20, 2015 | 1998 Chevrolet Blazer
They are typically mounted on the starter, there is a small block attached to the solenoid wire.
Apr 28, 2015 | Cars & Trucks
How do you bypass the security on these 98 chevy trucks? Is there even security on these trucks? I turn my key and nothing happens but I hear the inginition switch clicking with each turn of the key so is...
i have almost the same problem but mines a 98 5.0l vortec. the issue is i have no blown fuses but the truck runs low voltage all the time nothing above 12 volts. replaced the starter, alt, and starter hot wire. new battery. the starter relay was bypassed but it works just fine. idk what the deal is with this truck
Nov 29, 2010 | 1998 Chevrolet C1500
Starter wiring diagram for 98 buick century
This might be of help to you;
The starter wire is red in color with a (+) polarity which is located in the ignition switch harness..
Hope this helps..
Sep 03, 2010 | Buick Century Cars & Trucks
How do I remove the starter on a 98 2.4 chevy cavalier
jack up thecar and put it on stands, disconnect the battery the starter is behind the radiator on the rear of the engine, remove the two bolts that hold the starter on, then lower carefully not to pull the wires apart, disconnect the signal wire firle the the main, just reverse to install
May 04, 2010 | 1998 Chevrolet Cavalier
98 chevy 6cyl pickup standard trans sometime won't start ,sometimes when you turn engine of yoiu have to wait 20 minutes before it will start again. It has new plugs,new fuel pump,
You may have to inspect the starter relay or the starter. Also take a look at the wiring for some loose connections or bad wires that needs replacing.
Nov 02, 2009 | 1998 Chevrolet S-10 Pickup
Starter problems
not likely on a 98,u sure ur wired it right to right,umm ignition isnt sticking?
Aug 26, 2009 | 1998 Chevrolet Cavalier
Metra 2000 Chevy Tracker/Metro/Prism Logo
71 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
