Question about Canon PIXMA Office Equipment & Supplies
WHY CANON PRINTER MG2440 SHOWING ATTTENTION REQUIRED
1. WHEN CLICK PRINTING SHOWING ATTENTION REQUIRED. 2. NEXT WE WILL GIVE PRINT COMMAND IT IS SHOWING "PRINTER HAS A PROBLEM THAT REQUIRES YOUR INTERVATION.
2 Suggested Answers
  • 73 Answers
SOURCE: SHOWING ATTENTION REQUIRED PRINTER HAS A PROBLEM THAT REQUIRES YOUR INTERVATION
The page at the link below has a comprehensive listing of all of the error codes for your printer.If you do not find an answer there, you may need to find and install drivers for your printer.
PIXMA Printer Error Codes and Error Messages
Posted on Apr 28, 2015
Apr 28, 2015 | Canon PIXMA Office Equipment & Supplies
Canon MG2440 Reset
I think 5b00 is a print head failure, which means one of the cartridges is possibly faulty. Do you have any old cartridges you can put back in to see if the error clears?
Mar 02, 2015 | Canon Office Equipment & Supplies
Keeps printing old mess. can I clear all and start again
just go on printer n faxes
a window will open. just double click on ur printer i.e. canon pixma mx310, it will opean a dialogue box n shows ur printing status. dn select all the jobs command's n right click n cancel after dt a dialouge box will opean n ask u for deleate all ur printing commands. select yes .
All done.
start with new printing commands n get print's
May 29, 2011 | Canon PIXMA MX310 All-In-One Printer
Want to print a report of faxes sent today, manual has been lost. How do I print reports?
In order to get the manual online, please go to the below mentioned link:
http://www.retrevo.com/s/Canon-510-Multifunction-Printers-review-manual/id/3835bh435/t/1-2/
Click on " get the manual" and then on the next page download the manual.
The manual will give you on step by step procedure on printing various documents.
Aug 02, 2010 | Canon LaserCLASS 510 Printer
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
Vista 64-bit driver or windows 7-64 bit driver
Please note that PS121 does not require drives for its configuration. It can be configured manully using a browser:
Step 1:-
1.Connect the PS121 to the router & check the lights
2.Press the diag button with a paper clip, it should give a print out which should include a IP address (make a note of the IP address)
3.Open the browser & enter the IP address on the address bar, it should give you a prompt for a Username & password (Username = admin; password = password), this will show if PS is communicating with the network.
4. Make sure that all the firewalls are disabled (including windows firewall)
Step 2:- (For XP)
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Step 3:- (For Vista Computer):
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Nov 09, 2009 | NetGear PS121 Print Server
It just quit printing and copying
Hi ..
There could be multiple reasons for your printer not printing ..
1) Your printer is not setup as default.
2) Your printer drives need to be re-installed.
1) Your printer is not setup as default: If your printer is not your default printer, follow the instructions below to make it as default printer,
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.' On the screen, right click your printer and then left click on "Set as default" option.
2) Your printer drives need to be re-installed: If you have the driver CD then use it to re-install the software.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
When i give the command to print , it doesnot
Go to the Control Panel>Printer and Faxes>Double click on "HP Officejet 5610" and check that is any pending jobs or not in queue.
If yes then delete all of them and then give the print command.
If the deleting will not happend then shutdown your pc and on it after 2 min and then try to print.
If this is not helpful then :
1) Check all the cable of printer that it is attached properly or not.
2) Remove the printer driver and restart your machine and than install the fresh copy of your printer driver.
Mar 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Dec 20, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Printing takes a very long time
In this case you can bypass the spooler by the following steps:
1. Right click the printer icon & left click the printer properties
2. Click the Advenced tab in the printer properties.
3. Select the option PRINT DIRECTLY TO THE PRINTER & UNCHECK THE OPTION SPOOL THE DOCUMENT.
4. Click apply and ok.
5. Try printing.
Feb 08, 2008 | Office Equipment & Supplies
47 people viewed this question
old marine
old marine
