Machine is not run showing display DE - Washing Machines
Door interlock needs replaced
DE is DOOR ERROR
check ebay for a new interlock
Posted on Apr 28, 2015
The machine ask trouble dE
Google it perhaps using a make and error codes , will tell you what to look for
Nov 05, 2016 | Washing Machines
The display is showing alternating between CL and 0. What should I do?
How To: activate and de-activate child lock on your bosch ...
? 1:20
www.youtube.com/watch?v=lTXcTpalob4
Dec 24, 2012 - Uploaded by whichwasher2007 ... activate and de-activate child lock on the bosch logixxwashing machine range. ... you can turn the dial to '0', and thechild lock is still on, when your kid messes ... How to Identify anError Code on a Bosch Washing Machine ...
Oct 03, 2015 | Washing Machines
Machine show on display dE and stuck not working?
sorry no make /model we can not look for problem solution
Aug 01, 2015 | Washing Machines
LED not working properly
Yes, I have exactly the same problem after running the de-scale routine, we've only been using the machine for 4 months (in Melbourne where the water is soft). You can dimly make out the icons on the display and the machine works Ok. The display contrast is set correctly, yet the green images are not showing up properly while the red images do show up.
Sep 07, 2014 | Saeco Intelia HD8752
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
Hello,my fully automatic washing machine samsung is showing de when i on star the power switch ,it works without clothes but when clothes are inserted it shows the de display,why is it happening?
It's a bit unusual to have the difference between with or without clothes but 'de' normally stands for Door Error! There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
PS All I can think of is that the clothes make the drum/rubber surround drop sufficiently to trigger the 'DE'- strange!
Mar 21, 2011 | Samsung Washing Machines
The display show dE after a few minutes run
hello there:
dE - Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board Replace any parts that have failed any of these checks I.E lid switch ect .ect
Aug 07, 2010 | Washing Machines
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
