Televison & Video Logo
Wayne Daniel Posted on Apr 28, 2015
Have 8-yr-old Ilo CRT HD TV. Want to use Roku with it. What in port should I use? What is the Ilo channel that will show me the Roku screen?
27" 2007 model - cant find number
5 Related Answers
Anonymous
  • 211 Answers
  • Posted on Jan 07, 2008
SOURCE: White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Sumeet Sodhi
  • 163 Answers
  • Posted on May 31, 2008
SOURCE: ilo tv, model # dtv2784
try "0000"
A
Anonymous
  • Posted on Oct 05, 2008
SOURCE: JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Anonymous
  • 10594 Answers
  • Posted on Dec 06, 2008
SOURCE: Channel number does not go away
Press Display / Info button on "TV's Original Remote", on-screen display of channel number will disappear.
Anonymous
  • 3 Answers
  • Posted on Mar 09, 2009
SOURCE: RCA HD27F754T picture color and screen size.
check your hook ups, sounds like you have a component hook up conected to a composite jack.
1helpful
Pioneer plasma TV not working with Roku
Looks like it may be too old? Lots of help below, but this seems hopeful.
https://community.roku.com/t5/Roku-setup/Roku-Ultra-with-an-older-HD-plasma-TV-with-1080i-resolution/td-p/561009
Does a Roku Stick Work on Any TV? The Roku Streaming Stick 4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart TVs, as long as they have an HDMI connection.
If your TV is analog, don't worry! You can still use the Roku Streaming Stick 4K by using an AV Composite Converter. This will allow you to enjoy all the features of the Roku Streaming Stick on your TV.
All Roku streaming players will work for any television with an HDMI connection, so any Roku player can be connected to a 4K UHD or HDR-compatible television. However, to stream movies and TV shows in 4K UHD or HDR you will need a compatible Roku streaming player and television that supports 4K UHD or HDR.
Jul 24, 2023
Do I need a special TV? - Roku Support
Roku https://support.roku.com > en-ca > article
Does Roku Work on Any TV? Here's What You Need to Know
The Home Theater DIY https://thehometheaterdiy.com > does-roku-work-on-a...
2 days ago - Yes, Roku does work on basically any TV as long as it has an HDMI port. Older, lower resolution TV's probably don't need the most updated 4k ...
How to set up your Roku streaming player or ...
Roku https://support.roku.com > Roku setup
Jul 24, 2023 - From a USB port on your TV Any Roku Streaming Stick supports USB power, but only some Roku players do. If you are connecting your Roku device ...
‎Roku TV · ‎Roku Streaming Stick 4K · ‎4K TV · ‎Roku Streaming Stick 4K+
Compatibility Unleashed: Does Roku Work on Any TV?
Automate Your Life https://automatelife.net > does-roku-work-on-any-tv
1 day ago - The Roku Streaming Stick 4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart ...
‎Does a Roku Stick Work on... · ‎Steps to Install Roku on an Old...
1helpful
Is my tv compatable with a Ultra Roku which needs a HDMI port?
Roku is a media player, it is a small set top box manufactured by Roku. It streams multiple type of content and provides the output in an efficient manner. It has many channels and TV shows for user satisfaction. It has many users who enjoys the service and get entertained by watching their favorite channels.
Roku Ultra features:
    ·Roku Ultra is very fast, it is the most important product in Roku.
    ·It is the perfect features for the heavy streaming process.
    ·It provides clear and immersive picture quality.
    ·It is installed with 4K resolution, HDR support, etc.
    ·It is easy to use and more powerful.
    Roku Ultra provides the Ethernet port with wide connectivity. It can stream about 50,000 TV shows and 5, 000 channels at a time. It uses the micro SD slot to speed up the process. You can activate your device through Enter Activation Code for Roku. If you need details about Roku ultra you can get from go-roku-com-ultra. For more details contact@ +1-844-965-4357.
1helpful
3answers
Pros And Cons Of Roku
Roku is one of the best streaming devices to stream the videos, movies and TV shows.
Pros of Roku
The Roku offers user interface and Roku app in cheaper packages.
Roku does not require the separate box or HDMI cables to connect the TV from the stick plugs.
It has screen mirroring features that display the screens of the mobile device on you Roku tv.
It has the search function to search the lists of channels from the channel stores.
It provides headphone jack for private listening.
Cons of Roku
For the Network connection, Wifi is the only option
You need HDMI cable for Roku stick because it lacks analog and digital audio outputs.
If you need further more information about the roku products contact the roku customer service team @ +1-844-965-4357 and you may visit https://www.rokuactivationcode.com/
4answers
Will a roku work with netflix
Netflix Activation with Roku devices
  • Make sure that you enter Roku activate devices and also incorporated with the 5.1 audio options.
  • These 5.1 audio options are required for streaming of high quality contents.
  • So ensure your Roku device comes with these 5.1 audio options to enjoy high quality screening.
  • All the devices have Subtitles and captions as a default options.
  • Netflix avail users with Parental controls options and they can set their own Individual Profiles.
  • For Roku 1 model Go to Home screen > Select Netflix. You can visit channel store and your preferred Movies and TV shows are selected from there. Once you selected your preferences choose Netflix and add channel option is clicked to add your favourite shows.
  • In case of other Roku models, Go to Home screen > select Netflix. Go to channel streamed and then select preferred Movies and TV shows. Select the SignIn option from home screen activate Netflix in Roku to stream your preferred contents.
Signing out of Roku
Make sure that you enter Roku activate devices and navigate to Roku Home menu by pressing the home button. Select the Setting and choose Netflix settings from the menus. Select Deactivate the player from the Netflix account and chose the option yes now your Roku device will be deactivated.
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Vertical red lines apear on Sony XBR after Roku install
try re-botting your HDbox,also refit your scart lead to your box & t.v.
If you drop me an e-mail I will go through how to re-bot your box,if you don't know - re-botting your box helps pull in all the new software for your box - think it like a pc needing to update the programmes.
e-mail [email protected].
My tv will only display ch. 2 my little 5 yr. old was playing with the settings it is a 15 yr. old zenith tv
Depending on your market, it sounds like all of the other analogue channels have been terminated (not your son's fault) in order to provide stronger HD signals. You may need to run to wallmart and get that $50 decoder box.
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
