Take apart and fix 808 canz speaker - Audio Players & Recorders
The cap on my zebco 808 is stuck how do I get it off?
You might try disassembling, cleaning and reassembling the cap.
this is an excellent step by step guide to help you fix it. How to Take Apart Zebco Reel
Jun 02, 2014 | Sport & Outdoor - Others
My canon ir1024if has error 101 what causes it and how can i fix it
Error 101 is not listed. However 808 is and this requires you replacing the fuser assy. What do you mean "after the blow"??
Dec 17, 2013 | Canon IR1024IF 220V 240V AC10 50/60HZ
Overload pioneer vsx 808 rds
if it's shutting down when you increase the volume, this usually indicates a bad speaker.
Jul 03, 2013 | Audio Players & Recorders
Unlock
Is your phone network locked? . If yes , then you can unlock the network lock of Nokia 808 PureView using Unlock code . You can get the unlock code from SimpleUnlocking.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Nokia 808 PureView .
May 30, 2013 | Nokia Pureview 808 Sim Free Unlocked...
My Onkyo 808 shuts down when i raise the volume, and when I try to set it up using the micophone.
Amps shut down in most cases because the receiver is detecting and impedance (below 4 ohms) that might damage the amplifier. Do a quick check of the speaker connection and look for wires that might be shorted to the frame or have crossed each other. This is the most common cause of the unit shutting down. Check your speakers impedance if you have a meter. If you don't then unplug power from the unit and then un-hook all speaker wires from the receiver. Next connect just one speaker (Front Left) and power the unit back on and take the volume up. If it shuts down then try the Front right all by itself, bring the volume up again. If the unit seems ok then add one speaker at a time and test. Continue until you find the bad speaker/cable. Your amp should be able to drive speakers down to 4 ohms. The NR808 has power monitoring (sometimes called crowbar) that looks for to much current and then shuts down. I suspect you may have a short in a cable or in a speaker. The 808 is a great amp and hopefully your problem is external. If your amp continues to shut down even with just one speaker connected then one or more of your channel amps (internal) is likley bad causing the unit to shut down. Good Luck.
Dec 09, 2010 | Onkyo TXNR808 Receiver
Using s-cable...no sound...Please help!(to Telefunken lcd tv)
You won't have any sound. the s vidio cable is for video only. You need to use Your computer speakers.
May 25, 2009 | AOpen DVD Player (AOPDUW1608CG) Burner
Pioneer vsx 808 rds poweroff?
Could be lots of things, could be the tray not fully loading, or power supply problem...
Dec 03, 2007 | Pioneer DVR-520H DVD Recorder
484 people viewed this question
 Grubhead
Grubhead
