Question about Hayward SAND FILTER, PRO SERIES
I JUST REPLACED MY HAYWARD SP0714C SPIDER GASKET AND NOW THE BACKWASH PORT IS LEAKING LOTS OF WATER WHEN ON THE FILTRATION SETTING. WHAT DO I DO?
  • Hayward Master
  • 1,631 Answers
The spider gasket did not seat properly!
Take it apart and try again.
get the inside of the valve body completely dry, and make sure the grooves in which the gasket seats, are completely cleaned and free of any old sealant or gasket material.
Then apply a little bit of Silicone sealant, not much, into that groove. Then reassemble. Do NOT turn pump on for at least 8 hours to provide time for the silicone to cure, then try it.
Hopefully this helps you.
Good Luck.
Posted on Apr 29, 2015
john224
  • 1378 Answers
SOURCE: Filter is leaking out of the head backwash port when in the
Either the gasket 'groove' had debris in it and needs to be cleaned, the gasket rolled out again, or there is a crack in the area the gasket sits allowing the bypass.
Posted on Jun 13, 2009
  • 93 Answers
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
  • 990 Answers
SOURCE: My Hayward Swimpro Sand filter is not backwashing
Be sure it is not plumbed backwards and be sure you got a sand valve as a DE plumbs the other way.
Posted on Jun 26, 2010
  • 990 Answers
SOURCE: My hayward s230t sand filter is leaking out the
If you remove the top of the valve you will see a spider gasket that has pulled out of place. remove this and clean and dry throughly. Add a small amount of silicone sealer to the bottom of a new one and install in groves then replace top of valve and let sit for a couple of hours. That should fix. If not you will need to replace the top half of the valve also.
Posted on Jun 27, 2010
  • 760 Answers
SOURCE: We have a hayward sand filter and have replaced
There is more than one version of these valves. The model like sp072 has a 5 spoke spider gasket that has one opening larger than the rest. Be sure it is in position so that the large opening lines up with the large opening in the valve. If it's a SP0714 then the rubber is molded on the valve itself and would have to be replaced together. In either case, the seal is provided by the spring pressure forcing the valve faces together. That is why you should depress the handle, and only turn the valve while it's depressed, and the pump is off. After you turn to the selected location, then you release handle, and the valve surfaces should spring back together. Be sure the lever has spring tension on it in case you left it out while working on it) You can download complete manuals from www.haywardnet.com Good luck!
Posted on Aug 07, 2010
Drain leak
The spider gasket in the valve needs to be replaced. It is underneath the handle assembly.
Aug 26, 2013 | Hayward SAND FILTER, PRO SERIES
Water leaking from backwash even after replacing spider gasket
The Cam portion of the valve is worn. replace the "Spider Web" 4 times always replace the cam also on the 4th time. be sure to use a good HEAVY pool lube, I prefer Jacks 327.
Jun 29, 2012 | Hayward SAND FILTER, PRO SERIES
I have a brand new filter..im leaking lots of water from my backwash when on my filter setting
Your multiport spider gasket is bad. Just replace it by removing the top assembly. Remove the 6 phillips screws on the valve cover and the whole assembly will come off. This is easiest done when the valve is first put on the "Winter" position
Jul 21, 2011 | Hayward Pro Series 18" Above Ground Pool...
When I was moving the handle to backwash I couldn't hardly move it and after I moved it back to filtration position the water wouldn't stop running through the drain hose.
This problem occurs when the "spider" gasket inside the multiport valve fails. This repair can be done by a homeowner but requires a few things. 2 c-clamps, the new spider gasket, and chlorine safe adhesive/caulk to seat the gasket.
I dont know what model multi-port valve you have as there are 3 model that fit on this filter. Here is the link to haywards manual site where you can find a manual on your filter, and your valve that will list instructions and part numbers.
http://www.hayward-pool.com/webapp/wcs/stores/servlet/ProductInfo_10201_10551_14502_-1___I#PumpsIn_Ground
Hope this helps
Mar 30, 2011 | Hayward SAND FILTER, PRO SERIES
My pump is on filter but is draining the water out please help
The water Has to be going out the 'backwash' or 'waste' line.Either that or you have a leak in the plumbing. If the backwash/waste valve is set in the 'filter' position and there is still water escaping through the backwash/waste line, it means that the o-ring or spider gasket needs to be replaced or re-seated. If it is a multi-port valve (one that you spin to select the setting as opposed to a 'push/pull valve) you can try shutting off the pump; do a complete turn, 360 degrees, from the 'filter' setting all the way back to the 'filter' setting. This sometimes helps the spider gasket re-seat
Nov 27, 2010 | Intex Wet Set 300 GPH Swimming Pool Filter...
My filter and pump will not retain the prime after turning off. Its a pantera sand filter. I can hear an air hissing sound coming from the multi valve port
Either you have a bad spider gasket inside the multiport valve or a bad threaded fitting going into it. Check for leaks around the multiport and backwash line. You'll have to take apart the multiport valve to make sure the spider gasket is not damaged or out of place. Make sure to install the multiport valve in the same position. You can get a replacement gasket at most pool supply stores or online.
Oct 29, 2009 | Hayward Pool Products HAYWARD HEAT PUMP...
What do i do with the waste line port on the multiport valve on a hayward filter. do i attach a fitting to stop air
No. That port is there for when you backwash or pump to waste. You normally put a hose adapter there that allows for a collapsable backwash line to be attached when ready to backwash the filter. If it is leaking water there when the valve is set to something other than waste or backwash yuou need to replace the internal gasket in the valve.
Aug 08, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
169 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
