LEAVE MY PIN NO. - Computers & Internet
    Champion:
  • 261 Answers
This is called " erasing the password" Unplug the computer. Remove the battery for two minutes. It is a silver colored disc on the motherboard. Replace the battery and plug the computer back in. When you boot there will be no password, so you can change the BIOS settings to what you want.
Posted on Jul 11, 2015
I have a xo vision xo1943bt stereo and when I try to hook up Bluetooth to my iphone iit says to enter pin # what is that and where do I find pin #
The PIN number is to be able to pair your mobile device with the bluetooth device. OK, the default pin number for your model is 0000.
I'll leave a link here for you to download the manual. http://www.xovision.com/pdf/XO1915BT.pdf
Jan 29, 2016 | XO Vision Car Audio & Video
Pin for start up
if you never set up a pin then when ask for one just leave blank and press enter and see what happens if that does not work that means that someone else has set up one and you will have to take it in and have it reset
Dec 28, 2013 | RCA Tablets & eReaders
Enter client device pin
The client device PIN is a WPS method to connect to the network
I would suggest you disable the WPS feature and go with standard WPA or WEP
To get the PIN :
Turn off / Disable wifi in the laptop
  1. - Hardwire the computer and router
  1. - Open the router setup page ( http://192.168.2.1 )
  1. - Click wi fi Protected setup on the left side
  1. - Scroll down a little and you can find the router PIN
  1. - This is the number that you need to enter in the device
To Enable WPA Security in the wireless network
  1. - Leave the password blank and click submit
  1. - Disable Wi Fi Protected setup at the top and click Apply Changes
  1. - Click Security under wireless on the left side
  1. - Change the security mode to WPA
  1. - Type a password
  1. - Save the changes.
Dec 17, 2013 | Belkin F5D8631-4 Router (F5D8631au4A)
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Do you need a 24 power plug? for this motherboard? http://www.supermicro.com/products/motherboard/P4/E7210/P4SCi.cfm and if not how do i connect it then with a 20 power plug?
Its better if you have 24 pin power plug. If you don't have you can use 20 pin power plug also.
Insert the 20 pin leave 4 pin blank it will work.
May 05, 2011 | SuperMicro P4SCI-RETAIL (NEWITEM17006569)...
No keyboard, no display, doesnt sound like computer boot ups
firs remove the cover and remove the 24 pin conected to the motherboard from the smps you will also see another 4pin conector conected to your motherboard from the smps remove them to then short the pin green and bleck in the 24 pin connector and see wether the smps fan is working if working coneect the 24 pin to the motherboard leave the 4 pin aside and switch on the computer if the processor fan is working switch of the computer and connect the four pin conector to the motherboard and switch on the computer if the processor fan is not working then you have problem with the motherboard
Jan 29, 2011 | HP Computers & Internet
I have secure belkin router how can i undo or remove security. I can not log on youtube on my HTC phone.
naumita,
To reset a router to the factory settings:
1) Leave the router plugged in and on.
2) Locate a pin size hole; usually on the back or bottom.
3) Use a paperclip sized item and insert it into the pin hole and press in and hold for ten seconds.
4) Leave the router on and do not restart. Give it a few minutes to fully reset.
-Chris
Sep 04, 2010 | Belkin Home Security
Pin code
You should leave your pin code to immediate. It creates more security for you.
Jun 01, 2010 | Apple iPhone (16 GB) Smartphone
How do you find the pin code
Ok with all bluetooth or mostly all the pin code is 0000 four zeros now if that does not work then its not comptable with your pairing device so make sure its fully compatable before you leave me bad ratings. I know its 4 zeros i have one and these do not change.
thanks i hope this helps please do leave positive feedback and ratings for your free answer today.
Apr 27, 2010 | Motorola Mobility H390 Bluetooth Headset
How do i remove the pin on the crank pulley
Why do you want to remove the crank pully pin? Anyway, to remove this pin, you need to remove the pully first. afterward, you can use a pair of vice-grips to twist the pin out. However, not advisable. You should leave the pin there as it helps stabilize the crank pully & keeps it from turning on the crankshaft.
Oct 07, 2009 | Hyundai Motor 2004 Sonata
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
