Question about Murray Garden
I backed my Murray out...just moved it about 15 feet. Now, half an hour later, it won't start. WHY?
SOURCE: Ford F-350 Power stroke 6.0 L difficult to start
on both a 7.3l and 6.0l oil pressure is everything. Both engines use two oil pumps one for lubrication and one to fire the injectors. if your high pressure oil pump (inj pump) is weak it will take a long time for the truck to start. In order for the ficm to fire the injectors it wants to see at least 250 - 400 psi of ICP pressure. you will need a scanner to determine your high oil pressure at crank. Let me know how you make out.
Posted on Oct 25, 2008
  • 100 Answers
SOURCE: audi starting
you may of dislodge a main fuse, check them for security and integrity
Posted on Feb 18, 2009
Hightower971
  • 183 Answers
SOURCE: 91 vw golf will not stay running after 15 minutes
You are losing oil pressure, this means your oil pump is probably out. Don't drive it anymore until you can get that repaired. It's shutting down because it's siezing up. You need the extra power to jump it because the piston rings and wall are sticking together, let it all cool down and the rings contract and loosens up. Allowing the engine to turn.
Posted on Apr 24, 2009
  • 35 Answers
SOURCE: volvo 850 won't start occasionally
Hey Kolby!
Sounds like you've got an issue with your alarm module, causing the immobilizer to activate (also known as a "start inhibitor"). I'm not sure what type of alarm you've got, but this will probably help you find out if there is something wrong with it:
There is a panel with relays on it behind the dash. At the bottom of the steering column, by the drivers feet, there is a panel. Remove it to get access to the relay panel (just a couple of torx screws, no breakable clips as far as I can remember). Remove the "double size" relay (probably marked 210-211). Put a wire between the terminals 50E and 50F. This will hotwire the immobilizer and make sure that it always activates when turning the key.
Drive around with the wire in place instead of the relay for a while to see if this helps. If it does you'll know that the problem is related to the alarm system. Keep in mind that you will be without alarm and therefore probably also without remote central locking while doing this.
Make sure that the wire is connected firmly enough so it doesn't come loose. You can also put a fuse on it if it makes you sleep better at night ;)
Posted on Jun 27, 2009
  • 36 Answers
SOURCE: the dolphin stopped working.
drive belts on inside are worn and skipping over the gear on the inside. replace drive belts.
Posted on Aug 30, 2011
Why won't it start?
Honda Pilot 2005 won't start dead starter - YouTube
? 2:48
https://www.youtube.com/watch?v=tH2rEYLbQrY
Sep 15, 2011 - Uploaded by Alexey Gavrilov
Honda Pilot 2005 won't start dead starter ... How To Replace a Starter 2006 Honda Odyssey -EricTheCarGuy ...
Today my Pilot won't start! - Honda Pilot - Honda Pilot Forums
www.piloteers.org > ... > General > Problems
Mar 13, 2011 - A half-hour later, I got in to move it back, and the Pilot would not start. All the .... Most original batterys from 2005 need to be replaced by now. Starting Problem 2005 EX
Feb 24, 2011
Cold Weather (0 deg F) 06 Pilot won't start after jump - Honda ...
Jan 17, 2009
Engine won't start - clicking sounds and guage flutter - Honda ...
Dec 23, 2007
Starting Problems
Mar 24, 2006
More results from www.piloteers.org
Thread: '05 EXL won't start - HondaSUV.com Forums
Jan 01, 2016 | 2005 Honda Pilot
Craftsman riding mower runs mows fine for about 10-15 mins then sputters out and wont restart tuill bout half hour later
two things can be doing this ,
(1) fuel tank pick up is broken in half and works till gas works it way down to break , proof of this is when u add more gas and it starts right back up
(2) breakdown in ignition system , this can happen in a few places (if I knew your model number I can tell u more) eventually It will fail and never restart
Jun 07, 2014 | Craftsman Garden
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
The gear selector on my 2002 Ford Windstar moves, but the transmission won't go into gear. Why is the transmission not going into gear?
try to replace transmission strainer first torque convertor and see if that helps if not it probabaly the transmission
Jan 31, 2013 | Cars & Trucks
2000 vw passat wont start then 30 min later it starts
When it won't start do you get a click at all from the starter or not?
Jun 13, 2012 | Cars & Trucks
1991 eagle talon will crank, but won't start up. 2 days ago I was driving home from work when i turned around in a parking lot and went to my parents house. about a half an hour there i needed to move...
That sounds like the fuel pump may have lost it's prime. Does it have fuel injection, or a carburetor on the engine? How much gas was in the tank while it was parked on an incline? Have you tried any starting fluid sprayed into the air intake hose, toward the engine? Warning! Don't use much starting fluid! Perhaps a one or two second burst, and have someone crank it immediately after you have stepped back at least 6 feet from the engine. If it fires, then it is definitely a fuel delivery problem! But it won't run long like that unless the fuel pump starts working again ... which is most likely when the engine is cold!
Apr 19, 2017 | 1991 Eagle Talon
Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Jun 22, 2009 | Garden
Apr 24, 2009 | 1991 Volkswagen Golf
Audi starting
Feb 18, 2009 | 1996 Audi A4
Garden Logo
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
