Question about Infogrames Project IGI I'm Going In 2: Covert Strike for Windows
How to fix the problem "mode could not have been initialized
Installation is completed, when i open the game coming a message box mode could not have been initialized
I've tried to install the game D_DAY (montecristo) on my notebook but the message displayed is: "Application Installed successfully. Rebootthe computer to complete the installation" but if i...
Hello
This could be a corrupt install,try uninstalling through add remove programs,then reinstall.
You may want to try running the game as administrator or in compatibility mode.
Thanks for using fix ya
Feb 10, 2011 | Monte Cristo D-Day for Windows
Hello Sir, when i am trying to open to Play MotoGP 08 then, its give me an error message like " Filed to initial directX " . can u tell me how to fix that ?
You need to just re-install the game..
While re-installing the game if it prompts for any direct X installation follow the instructions.
Nov 16, 2010 | Computers & Internet
Samsung s5233 unable to open message box as it says initializing
Apr 16, 2010 | Samsung Star GT-S5233 Cell Phone
SH3 gives me this errior "can not initialize 3D enine" ?
Try reinstalling the game. It sounds like the game files are corrupted or did not install correctly the first time.
Mar 09, 2010 | Ubi Soft Silent Hunter III for Windows
Problems with Age of Empires II
I think the game may need direct x to run
Problem apple does not have direct x
research on internet is pointing to emulating windows on Mac
and running dirext x in emulation ?
https://www.parallels.com/au/landingpage/pd/general/?gclid=CjwKEAiAi-_FBRCZyPm_14CjoyASJAClUigOnIf36NPJH6HLhU3gR7pjCfXoq_M5fkmTj1iGAnEpAxoCOH_w_wcB
Mar 05, 2017 | Macsoft Video Game Consoles & Games
Upon startup of game get this error message- "unable to initialize video mode: could not set screen mode."
try download n install latest driver..
Here is something you can try for now:
Many games provide an option to be started in "window"-mode instead of fullscreen.
Open a terminal, cd to the directory where the game is installed and start it from there, but append "--help" behind the command name (or "-h" if that didn't work)! Keep an eye open for an option that looks as if it starts the game in window-mode.
Jul 24, 2009 | Atari Desperados 2: Cooper's Revenge for...
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
Unable to open in full screen mode
i hope that you have installed display drivers, then go to the setting of the game check the display mode there
Nov 08, 2008 | Computers & Internet
Infogrames Project IGI I'm Going In 2: Covert Strike for Windows Logo
50 people viewed this question
Top Infogrames Video Game Consoles & Games Experts
newclique
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
EnergeeUK
Level 1 Expert
Are you an Infogrames Video Game Console and Game Expert? Answer questions, earn points and help others
