Question about Saws
How do I line up the blade for a prefect 90 degree
  • 932 Answers
Don,
Use a square.
Posted on Apr 28, 2015
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
Black and Decker Jig Saw BD533E. just changes blade and then cut is pulling to the right and not giving a cut thet is 90 degrees to the horizontal. This was my Dads - could it be the blades are not up to...
If you haven't done so yet check the base plate bevel adjustment setting to make sure it is setting at a 90 degree angle to blade and make sure that the shank on the blade is not bent or twisted. Hope this helps. Thank you.
Aug 15, 2011 | Black & Decker Garden
Saw is not cutting straight
Make sure the miter is lined up at 90 degrees to the blade. The fence has to be parallel to the blade and the blade tight. Cuts should be straight if the piece is held firmly and you move at the proper speed. Good luck!
Mar 05, 2011 | Dewalt D24000S Wet Saw With Stand
Installing blade on a bosch jigsaw
The black part on top of the handle must be pulled directly up about 1/2 an inch. this engages the screw mechanism that loosens the blade. For some people doing this the first time feels like they are going to break the handle but it moves easier over time. Now turn the black handle counterclockwise several turns and the blade will hang loose in the holder. Turn the blade 90 degrees and remove it. Place a new blade in and turn back 90 degrees. Tighten the handle on top until it clicks. Align the black handle to the main handle and press back down into place.
Jul 15, 2010 | Bosch 1587AVSP Top - Handle Jig Saw Kit...
How do I cut moulding for steps? What do the numbers on the table saw mean....like 22.5 degrees?
By default people keep their blade set to 90 degrees - perpendicular to the table. There are times you need to cut a beveled edge which is not 90 degrees.
The numbers on the saw refer to the bevel angle or how far from 90 degrees your blade is tilted.
http://www.askthebuilder.com/557_Stair_Trim_Molding.shtml might answer some of your other questions.
If this answer helped, please vote for it.
Jun 08, 2010 | Saws
Blade needs to go from 89 to 90 degrees. How do I adjust it?
not sure of the brand, but on most circ saws, there is a small screw in the bottom of the base plate. take a small screwdriver and adjust that screw until the saw squares up
Jan 31, 2010 | Saws
How do I change wiper blades on a Ford 500
This is a fairly simple job.
#1 Pull the wiper arm away from the vehicle.
#2 Turn the blade 90 degrees so that the blade and the arm make a 'capital T' shape.
#3 Pull the blade straight off of the arm.
#4 Install the new wiper blade so that it forms a ' T ' with the arm.
#5 Turn the blade back to the normal position in line with the arm.
#6 Ease the wiper arm and blade back against the windshield.
#7 You are done. Good luck
Jan 03, 2010 | 2006 Ford Five Hundred
The blade is not straight up and down I need to know how to adjust it. ****
With the unit unplugged, find the knob which controls the angle.
One of the turn knobs raises and lowers the blade. The other is tied to the degree labled pointer. usually you'll have to pull it out to engage the actual adjustment part. Crank it till the pointer is stopped at the top range where it says 90. To verify, i usually use a 90 degree right angle to make sure it's true 90 degrees.
Jul 07, 2009 | Craftsman 10" Table Saw
Older Delta 10'' Miter Saw Zero setting is out by 1/2 degree.
Undid the RH fence-bolt in the table behind the fence and tapped the end of the fence forward to make it perpendicular to the blade. Tighten bolt. When you look down on the two fence bolt heads, one is easy to rotate with a socket wrench, the LH bolt head would be very, very difficult to move. Undo the RH bolt to swing the fence angle WRT the blade.
Apr 08, 2009 | Delta Saws
Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Craftsman 10" Table Saw
Saws Logo
144 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
