Question about AOC Computers & Internet
The monitor would be fine if it would stop its flashing mode.
It also persists in trying to auto configure
5 Suggested Answers
  • 8 Answers
SOURCE: Auto Config????
Auto Config should (in theory) reposition the viewing area of the screen dependant on the resolution. So it fires up when the resolution your monitor is working at is different than the native one (1280x1024), if it's working in windows - set the resolution to 1280x1024 and it should work ok. right click on desktop>properties>settings p.s. also set the refresh rate to 60 hertz.
Posted on Oct 24, 2006
LadyTech99
  • 141 Answers
SOURCE: processing auto configuration
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
Posted on Dec 11, 2008
SOURCE: My auto configuration menu on the monitor keeps po...
auto configuration menu stays on monitor screen constantly while trying to use pc for normaluse.
Posted on Aug 23, 2010
chiplevel
  • 656 Answers
SOURCE: asus monitor keepa flashing either
first remove the display cable from CPU and see wether the CPU is stable if not its with your monitor next start Ur CPU with VGA cable connected press F8 you will come to safe mode section click safe mode then you will see some files running wait till the desk top comes in safe mode the computer shows only is default if the monitor is stable right click my computer click properties then hardware then device manager the expand display adapters uninstall them and restart if still the monitor is not stable check your CPU with another computer or check your monitor with another CPU
Posted on Oct 28, 2010
My OCD/ processing auto configuration keeps flashing on and off on my screen how do I stop it?
check the system for viruses ..
try using a different user account ... see if the problem persists in safe mode ..
if that does not help, then call 1-877-805-1027 for expert help.
Jul 17, 2015 | Gateway Computers & Internet
At start up---acer logo keeps coming on and going off every 10 seconds.then green light finally stays on and able to use computerwith no problems. only problem is at start up. takes five to ten minutes to...
Try replacing the video cable connecting the monitor to the computer. If this does not help, try setting the input on the monitor to the specific mode that you are using (VGA, DVI, etc.) from auto detect. If this does not work, try to replicate the issue on another computer. If the issue persists on another computer, than you most likely will have to replace the monitor; if the problem stops, then this is an issue with the computer itself.
May 05, 2011 | Acer Computers & Internet
Monitor flashing on my screen processing auto configuration What does this mean
It means the monitor is configuring itself to a usable operation mode. i.e., the correct resolution screen size etc.
Hope this helps.
Sep 12, 2010 | Computers & Internet
My auto configuration menu on the monitor keeps popping up and cannot get it to stop what can I do?
May 20, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
How do i stop my monitor auto configurating? I have a AOC LM500 monitor and every 5 seconds the screen goes black the it auto configures... i dont know how to stop it
Your auto-configuring settings are located on your monitors settings. Depending on the monitor, there should be a settings button somewhere on the monitor itself. In the settings there will be an option to change the monitor to your settings or "auto configuring". You'll know what to do from here.
I hope this helped.
Apr 15, 2010 | Computers & Internet
A MESSAGE KEEPS POPPING UP ON MY SCREEN AUTO CONFIG HOW DO I STOP IT
Think I fixed it.. My monitor kept flashing autoconfig and shaking a little, so I went to control panel - clicked on system - clicked Hardware - clicked on device manager - clicked display adapters - and updated the driver. Re-booted computer..
So far so good... Fingers Crossed..
Oct 23, 2009 | Acer Computers & Internet
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
Processing auto configuration
Nov 18, 2008 | Acer AL1711 17" LCD Monitor
Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the...
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
May 12, 2008 | Computers & Internet
Acer AL1511 15" monitor Screen Menu Problem
What operating system do you use? If it is a windows OS press F8 while the system is booting to access the Boot Manager, choose to boot to last known good configuration and if this does not work retry but select safe mode and change the resolution back to the previous one.
Jan 19, 2008 | Acer AL1511 15" LCD Monitor
Computers & Internet Logo
106 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
