Question about Kenwood KDW60X13 600 mm Stainless Steel Freestanding Dishwasher 14 Place Settings, A Energy Rating
Hi my dishwasher starts fine gets about half way through the cycle and then turns itself off.
The dishwasher is 18 months old regulary cleaned and manitain everything works fine just wont complete a cycle can you help ?
    New Friend:
  • 90 Answers
You might need to reset the washer by cutting it off and then reset it
Posted on Apr 28, 2015
Water won't flow into the dishwasher
It depends how old your dishwasher i. If it is more than 18 months old and gets heavy use then grease and food debris can block the internal pipework. You can manually fill the dishwasher and use a dishwasher cleaning bottle that can be bought from most supermarkets. Run it on the hottest setting possible with nothing else in the dishwasher. Also remove all the filters and strainers from the bottom of the dishwasher and wash these by hand using hot soapy water. Do not put back into dishwasher until the cleaning cycle has finished.
This may work but if the pipes are too badly blocked then the dishwasher will need to be stripped and the pipes cleaned by hand
Aug 04, 2013 | Samsung Computers & Internet
Whirlpool ADP2315 dishwasher has stopped working
sound like a repair man problem, but at 18 months I would think it is still under warranty. If not at the store if you pay with some visa cards they give you and extra warranty so you could check with them as well. hope it works.
Oct 04, 2017 | Whirlpool Dishwashers
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
My dishwasher will start any cycle then half way
The touch pad has gone bad. Common problem with the GE made dishwashers.
May 12, 2010 | Dishwashers
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Dishwasher not cleaning well
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Good luck!
Aug 17, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Kenwood KDW60X13 600 mm Stainless Steel Freestanding Dishwasher 14 Place Settings, A Energy Rating Logo
292 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
ashburton
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
