Question about Health & Beauty
1.76cm = feet? - Health & Beauty
What is cubic feet in 11 feet by 21 feet
You cannot calculate cubic feet from only two measurements. Cubic feet is an area of volume, such as the inside area of a box. With only two measurements you get square feet, which is a measurement of area. A box 11 feet by 21 feet takes up an area of 231 square feet (11 times 21). If the box is 3 feet tall, then you can compute cubic feet since you take all three values and multiply them together. A box 11 feet by 21 feet by 3 feet would contain 693 cubic feet of space (11 times 21 times 3).
Feb 15, 2016 | Office Equipment & Supplies
How many linear feet is in a piece of carpet that is 5'x7'7
Linear feet (often called Lineal feet) are the same as regular feet. No conversion is necessary. If something is 6 linear feet tall, it is 6 feet tall. FAQ What is linear feet How do convert it to feet FAQ What is linear feet How do convert it to feet
Nov 24, 2015 | Measuring Tools & Sensors
I need the liner feet of a boat that is 18.3 feet long and 6.7 feet wide and 4?7 feet high
What is "liner" feet? Do you mean "linear" feet?
Linear feet are actual feet - no conversion required. If it is 6 linear feet wide, or tall, or deep - then it is simply 6 feet wide, or tall, or deep.
Apr 26, 2015 | Office Equipment & Supplies
What is 25 linear feet in square feet
That depends on the length and width.
24 feet 11 inches by 1 inch is about 2.01 square feet.
24 feet by 1 feet is 25 square feet.
20 feet by 5 feet is 100 square feet.
12.5 feet by 12.5 feet is 156.25 square feet.
Sep 08, 2014 | Office Equipment & Supplies
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
9.4 feet by 3.5feet is how many cubic feet
It isn't. 9.4 feet by 3.5 feet is an area. Cubic feet is a unit of volume.
If you have a pond that's 9.4 feet by 3.5 feet, how much water is in it? Well, that would depend on how deep the pond is, wouldn't it?
9.4 feet by 3.5 feet by one inch is about 2.74 cubic feet.
9.4 feet by 3.5 feet by one foot is 32.9 cubic feet.
9.4 feet by 3.5 feet by two feet is 65.8 cubic feet.
May 04, 2014 | Office Equipment & Supplies
How should I pick the right TV size?
In general, for best image quality and bestexperience you need 32 inches TV for every three meters. For example if in yourliving room your distance from the screen is 6 meters the recommended foryou is 64 inches. I've attached a table with exact s and ranges for yourconvenience Screen Viewing distance range 26" 3.25 - 5.5 feet 32" 4.0 - 6.66 feet 37" 4.63 - 7.71 feet 40" 5.0 - 8.33 feet 42" 5.25 - 8.75 feet 46" 5.75 - 9.5 feet 50" 6.25 - 10.5 feet 52" 6.5 - 10.8 feet 55" 6.9 - 11.5 feet 58" 7.25 - 12 feet 65" 8.13 - 13.5 feet 70" 8.75 - 14.75 feet
Jul 29, 2012 | Furniture
What is the official size of a ping pong table?
the table should be rectangular: 2.74m long and 1.525m wide, 76cm above the floor.
Jul 09, 2012 | Sport & Outdoor - Others
I have a 30" (76cm)
Most ovens have either a flat piece of glass with clips either side covering the oven light or a round glass knob which unscrews. The glass covers can sometimes be difficult to remove due to heat and fat build up. You can tap the flat glass with a blunt object. You can use multigrips on the glass knob, just be careful.
Feb 14, 2011 | Whirlpool Ovens
Lost remote and want to turn child lock off on a teac 76cm widescreen model no: EU3216STF
you will have to find out if you can acess the menu via any control on the tv itself,If this is not possible,then you will have to purchase a universal remote that will bring up your menu.
Feb 10, 2008 | Televison & Video
Health & Beauty Logo
325 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
