Question about Garden
The shut off plate does not fully close when release handle. Have recalibrated and still won't fully close.
2 Suggested Answers
dttech
  • 4803 Answers
SOURCE: c320 hood release handle won't pop the hood
I don't think there is a day that goes by in the shop where we don't get at least one vehicle that is doing this. Just use two people. One to pull the cable release and the other to slap the hood with their hand and tell it to cooperate. Usually, just a little "jarring" with the cable pulled will get it to pop up.
Posted on Apr 14, 2012
My boot wont close fully
  • Press down on your trunk, and have somebody release your trunk's release mechanism from inside your car simultaneously. These systems can become jammed but can sometimes be released if a gentle downward pressure is applied to your trunk while the mechanism is being activated. If this is the problem, apply some lubricant.
  • Clean the latch and the area where it connects to the chassis. If dirt or debris has become lodged here, it can stop the latch from connecting properly. It's a good idea to vacuum the area to ensure no small bits of gravel have become trapped and stopped the mechanism from securing properly.
  • Examine the latch and the area where it connects to the body of the car. Either of these might have become bent out of shape or damaged in some other way if the trunk has been shut with an obstruction in the way. If this is the case, contact your vehicle's manufacturer or a local garage to find a replacement if the elements cannot be repaired.
Check the latch mechanism, it may have accidentally already be in the closed or lock position. If it is, you will have to pry down on the latch tangs with a screw driver while pulling latch handle to the open position.
Latch could also be seized, in that case , use a thin oil liberally on latch mechanism, and work the mechanism open and shut closing and opening with screw driver and boot handle.
How to fix trunk that won close 2006 2008 civic for less than 5
Jan 23, 2016 | Skoda Superb Cars & Trucks
We opened the door, now door won't close. The closer rod is locked open
Turn the screw in the end of the shaft (on the door end) counterclockwise to release all the pressure.Once it closes or slams shut, use that screw to adjust the closing speed. Other problem could be the stay open lock (the metal piece that slides along the shaft) could be all the way out keeping the door from closing. If it is just push on the door a bit then slide the lock plate all the way back to the end of the shaft, and the door will close.
Dec 21, 2013 | Wright Products Tap-N-Go White Screen and...
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
1979 landcruiser clutch did not release fully to get it into gear.I had rebuild the master and slave silinders.The problem is stil the same.
Problem might be on the Clutch plate is won or Preasure plate is weak wants to be changed. or sometimes your slave cylinder is won inside, fix complete new one and then see before going deep in the gearbox.
Aug 27, 2011 | Toyota Land Cruiser Cars & Trucks
Selector knob spins, no clicks, does not select the weights. The metal disk near the handle does not move.
1. Check to assure that the ******** handle is fully depressed into the ******** base. If not fully depressed, the locking mechanism will not be released and may be keeping the adjustment knobs from rotating. 2. Check to see if any weight plates have been put into the base assembly backwards with the "support ******" facing the grip of the ******** handle. All weight plates must have the selection ****** facing away from the grip of the ******** handle. 3. Check to see if there is any dirt, debris or other obstruction in the ******** base. You may need to remove the weight plates from the base to accomplish this check. Remember to put each weight plate back in its appropriate location with the selection ****** facing away from the ******** grip.
Aug 15, 2011 | Bowflex Selecttech Dumbbells
Kirby Generation 3: Having trouble putting plate back on where electrical cord attaches. Ever since the shop put a new cord on for me, I have trouble using release lever for dropping the handle when I...
There are 2 tabs on the bottom front edge of the switch plate which slide under the metal top cover. Make sure these tabs have not gotten bent upward so they will not slide under the top cover. If they are bent, simply pry them open. Also, note that the handle pivot has a sliding latch on it to allow the handle to be fully lowered. To lower the handle flat, push the little knob inward.
May 03, 2011 | Vacuums
OBDii codes 2104 and 2112 for TAC. Is there any thing else to look at before repacing the throttle body?
OK this is the loop. You put your foot on the gas and the ECM calls on the throttle actuator control (TAC) motor to open the throttle plate. A throttle position sensor (TPS) on the throttle plate shaft feeds back to the ECM the position of the throttle plate. If there is an interruption of signal either to the TAC or from the TPS the ECM sees the lack of agreement and shuts the system down and sets the throttle to idle or 16 degrees to allow you you to crawl home. In the old days when the throttle position was dictated physically by the throttle cable directly I would have suggested that, with the engine off, the throttle be pushed to the maximum and released quickly to reset the TPS and allow the ECM to recalibrate. First check that the throttle body interior and plate are spotlessly clean. If the throttle interior is dirty the throttle plate has to opened wider to allow air passed the film of grime lining the throttle and the ECM may see this as a lack of accord between the TAC requested and the larger than expected TPS return signal. Check that the wiring connections to the throttle body are clean and bright. Check that the TPS interior is clean and no grime has got between the throttle shaft mounted slider contact and the circular contact strip - if you suspect that this is an issue spray clean with electrical contact cleaner (only use this as it leaves absolutely no residue). Open the throttle plate fully using you fingers and allow it to snap closed on its spring. If you suspect the TPS as the cause of the error here is some generic detail:-
How to check? The socket for electrical connection with the TPS has 3 pins, one for 'ground', one for 5 volts 'reference' and a third (generally the middle one) for 'signal' output from the throttle plate slider. Back probe the signal pin in the connector to the TPS. Attach the positive lead of a voltmeter to the probe and measure the voltage output as the throttle plate is rotated (use your fingers to turn it). If working correctly the meter should show a voltage consistent with the throttle position from approximately 1 volt when closed and 5 volts when fully open. What is looked for is smooth voltage increase with throttle position change. If there are drop outs in the throttle transition voltage signal or if there is no transition then the TPS is faulty and replace it.
Jan 23, 2011 | 2006 Ford F-150
Volvo xc90 rear hatch door closed and won't open
Hold the hatch hard closed into its frame whilst pulling on the release handle. The mechanism on most cars consists a grab/release on the door and a simple metal hop at the bottom of the frame. Over time the hoop can become loose and move slightly inwards each time the door is shut. The door seal rubbers push back on the door surround putting a lot of tension against the grab/release mechanism preventing it from releasing. By pressing on the door and compressing the rubber surround you will take the pressure off the release mechanism and allow it to open when you pull on the handle. Once the door hatch is open, loosen the mounting bolts to the metal hoop and move it out about 10mm. Tighten the mounting bolts. Shut the door gently as a trial close and check for security of fit. If very slack, ease the hoop inwards a couple of millimetres. When happy, tighten the mounting bolts securely. draw around the hoop mount with indelible ink so if it moves in future you have early visual warning and can remount it easily
Jul 13, 2010 | 2004 Volvo XC90
My 2004 Toyota Sequoia rear door will not open - the handle is broken. How do I get into the door, whith it closed, to make the necessary repairs?
Dig out the broken bits of door handle, then on the right side insert a flat head screwdriver diagonally up and fish around for the release lever.
Push up on the screwdriver handle to manipulate the release lever down and your tailgate will open.
Remove the interior panels by unbolting the 10mm bolt behind the strap and pulling off the interior pieces held on by plastic pop fasteners.
Remove the 10mm bolts around the perimeter of the interior cover plate and let it hang by the harness.
Remove the license plate.
Remove the license plate trim panel (multiple push fasteners from behind and a few 10mm around the lock)
Replace the handle.
Sep 13, 2009 | 2004 Toyota Sequoia
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
