Question about Westinghouse Televison & Video
TV stop working. No power at all. What might be possible problem.
    Top Expert:
  • Westinghouse Master
  • 74,473 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 28, 2015
Tv turns off red light blinks 9 times
Sony tv led and blinking codes
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I hope this will be of some help to you
Mar 22, 2012 | Sony Televison & Video
My tv power led red blink 4times
Blinking codes are never good news
Please r5ate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-R60XBR2 Television
Sony kp65wv700 tv blinks 7 times - Horizontal deflection issue is what manual is telling me. My question is what transistor/chips I need to replace and if anyone has done that to fix this problem...
Here are the fault codes for your tv and what components are affected:
Feb 26, 2010 | Sony KP-51WS500 51" Rear Projection...
Turns on when cold and works fine for thirty seconds, then starts clicking in the back and picture goes out. Then tries to turn on and then just clicks off again. Continues to cycle like this, but never...
Pls check error code by counting the front LED flashes. Below is the list or error code and values;
0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted. 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode. 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped. 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small. 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture. 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board) 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board) 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Dec 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Panasonic 27 in TV
Power surges will attack every board in the unit, it is possible that they discovered that more boards were affected then could be changed for a reasonable cost. These tv's are not component level repair, but board level repair. There is no easy or good solution when a set has been severely damaged by a power surge. The best answer is usually to replace the tv. Also power surges are covered under most homeowners insurance.
Sep 05, 2009 | Sanyo DP26648 LCD TV
TV wont turn on
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board)Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Apr 06, 2017 | RCA Scenium HD65W20 65" Rear Projection...
Sony KP-65WV700 DVI-HDTV Issue
From here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Nov 12, 2008 | Sony KP-57WV600 57" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Jul 08, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY KDP 65WS550
are you sure it 10?
these are the codes i have
· 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
· 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
· 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
· 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
· 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
· 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
· 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
· 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television. If it is not enough, do not worry -- in the coming few posts I will talk about entering the Diagnosis and Service modes for your television set!
Mar 13, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
