Question about Sirius Audio Players & Recorders
How to wire up truck for sirius radio install
    Problem Solver:
  • 11 Answers
If this is an add on, then go online and search for the install manual for your radio. Or go to Best Buy or a local radio install shop for help.
Posted on May 13, 2015
5 Suggested Answers
  • 20 Answers
SOURCE: sirius radio
Cliff, If you mean a schematic then u are going to have a tough time finding that. It is manufactured by Directed Electronics, so you might try to contact them, but they might not be willing to divulge that info.
Posted on Feb 29, 2008
  • 20 Answers
SOURCE: Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Posted on Apr 27, 2008
SOURCE: sirius satellite radio
You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
Posted on Mar 13, 2009
  • 4 Answers
SOURCE: HOW DO I TAKE APART THE DASHBOARD ON MY 2006 FORD
If its like my ford ranger the dash is held together with small medal clips . start at the corner of the dash on the driver side and carefully pull the dash piece towards you. i've taken mine apart 3 times now and i find that the medal clips needed to be reshaped the third around make sure your vehicle is nice and warm or you will crack the plastic
Posted on Feb 13, 2010
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
Receiver not "receiving"
where is the antenna located make sure it is not covered by anything. Also make sure there are no kinks or breaks in the antenna wire
Sep 11, 2009 | Sirius Satellite Radio Sirius Starmate ST1...
Sirius satellite radio
Make sure the antenna has a good line of sight. Sirus works best when pointed in an Easterly direction. By default you should get channel 184 if there is no service activated on the radio.
All Sirius radios can be used for service only in the United States and Canada.
If you feel that the line of sight is ok and there are no obstructions from pointing your antenna either out of a window, on top of the car, or outside if it is used in a house, then try a different antenna. If you are using the smaller guage antenna wire, the connections can break inside during installation in a car from time to time.
If the radio is factory installed contact sirius at 1-888-539-7474 to see if they can see the radio on their end.
Oct 19, 2008 | Sirius Satellite Radio Receiver
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Oct 01, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
"buzz" when Sirius receiver is plugged into AUX input of new Camry
Did you have the unit installed at a shop that would have hardwired the power source? It sounds like either your power wire to the sirius unit is connected to a noisy power source (which is why you are picking up the alternator whine), or you have a poor ground connection to the unit. If it was installed at a shop, take it back and have them move the power source to the same wires that the radio gets power from. If you are using your cigarette lighter for power, unfortunately it sounds like your outlet doesn't give you the best source for powering an audio component. You might try stopping by a car audio shop and ask how much it would cost to hardwire the sirius' power to the back of your radio.
Nov 07, 2006 | Sirius Satellite Radio Sirius Starbase...
949 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
