Question about Samsung SCX-4828FN All-In-One Laser Printer
Paper feed pickup? - Samsung SCX-4828FN All-In-One Laser Printer
  • The Dude
    The Dude Apr 28, 2015
    Hi adrianjt , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • The Dude
    What's the specific issue?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Servicing or replace paper pikup parts: pikup roller , separation pads, solenoid etc
Posted on Aug 13, 2015
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
Blank pages when printing
Altinis:
Remove the paper tray and look up into the paper pickup area. The roller there is the paper pickup roller. Under the paper pickup roller is a paper double-feed prevention pad. Take a "Q-Tip" dipped in alcohol and clean both the paper pickup roller and the double-feed prevention pad. That should prevent the paper double-feeds that you are experiencing.
Feb 24, 2013 | HP Photosmart B110a Wireless e-All-in-One...
Paper wont feed
there are multiple reasons that paper won't feed into a printer. the pickup roller may be worn and doesn't grip onto the paper, or the printer tray may not be lifting the paper to the pickup roller.
Feb 23, 2013 | Canon Office Equipment & Supplies
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Plain paper feeds no problem but photo glossy paper wont feed! (epson 830)
Hi
This looks to be a problem with the paper pickup roller. Hence use a little thin Photo paper or replace the Pickup roller and also the Paper feed toller (Long black roller )
Jul 15, 2011 | Epson Stylus Photo 830 InkJet Printer
Paper will not "feed" from
this is an issue with the papper feed and pickup rollers if it is not taking the paper from draw you need to replace the pickup and feed rollers also check the paper feed clutch if no good replace as well
Also make sure also make sure the paper is being lifted up when you close the draw you should hear the tray lifting the paper up to the feed system
Feb 17, 2011 | Minolta EP4000/5000 CS/PRO Copier
Document won't print, but it sounds like it is
Make sure the paper feed is full of fresh paper. Print something, and watch where the paper feeds into the machine. If the feed roller actuates and tries to pickup the paper but doesn't, you may need to clean the pickup roller with distilled water and a qtip. If it still doesn't pickup the paper, repair it under warranty with canon or replace it if not under warranty.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper won't feed
More than likely you pickup roller is dirty.
You can try to clean to see if that helps.
If that fails, then replace the pickup roller.
Below is a service manual that will show you how to remove and clean the pickup roller and how to replace it if necessary.
LJ1020 Service Manual
  • Pickup roller RL1-0266-000CN 50,000 pages Affects paper pickup
Sep 04, 2009 | HP LaserJet 1020 Printer
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
Samsung SCX-4828FN All-In-One Laser Printer Logo
53 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
