Question about Canon FAXPHONE L90
I have an error during TX - Canon FAXPHONE L90
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
Fines not sending to email
try to scan it one by one as your scanner and processor is somewhat slow or defecxtive
May 17, 2013 | Canon imageRUNNER 3225 Black and White...
When you print out the activity report and under comment it says TX ECM what does that mean?
Transmission Error Correcting Mode was used. When the sending and receiving fax machines support this protocol, they are able to correct errors in transmission that occur. You can turn it off if it is causing you a problem, but it shouldn't be. It makes the determination about ECM capabilities during the initial synchronization. No positive response from the other and and ECM is not employed during the transmission.
Nov 14, 2010 | Brother IntelliFAX 4100 Laser Fax
My Canon MFP4150 cannot send international faxes. I keep getting error message 0091 : error during tx. Please advise a solution.
make sure the the phone line which you using having ISD calling facility in dialing 1 st you try that no by dialing with the normal phone.
Jan 20, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
0009: Error during TX message
Guys,
I got the same problems and then I contacted our PSTN provider and they configured the route. Now it is working fine!
Jul 18, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Sofltware
Need more info -
When is this happening?
- During sync
- When turning the Palm on?
Dec 12, 2007 | Palm TX Handheld
Canon FAXPHONE L90 Logo
66 people viewed this question
old marine
old marine
