Question about NorStar M7324 Telephone
Callers cannot call into roll-over lines, I am now the only one who can pick up incoming calls. I think when I changed the time I messed up the call settings. Any help on how to fix pleeease!! lisa
  • 31 Answers
SOURCE: Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Posted on May 23, 2007
sandiiii
  • 17 Answers
SOURCE: m7310
go and edit ur phone settings..its not ur fault it is by the operator..just contact ur gsm operator at call cantre and edit all the settings as he guides u........
Posted on Dec 04, 2007
SOURCE: caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Posted on Sep 21, 2008
SOURCE: Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
Posted on Jan 02, 2009
MNfisherman
  • 11896 Answers
SOURCE: Caller ID not working on my t7316 phone
You can copy and paste this link below to go to a site where you can download your entire manual:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Sep 16, 2009
I live in the USA. My caller ID stopped displaying incoming calls. Last incoming call on the display says 12.2.14. Even when phone is ringing, caller ID does not display name, number,time,date,etc.
Call Phone Co and see if you are programed for the Caller ID feature. In some areas this feature cost more. Whether or not you are paying for it, it may not be programmed in their switch for you?
Feb 06, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
GE 27938GE7_C call waiting
Yes, I re-read the manual and it says (under Caller ID) to press the flash/program button to answer the new incoming call...I must have hit the pound key in error thinking I hit the flash button. I have yet to try this in real time, but will next time it arises and report if it does NOT work.
Nov 09, 2008 | Uniden Cordless Phone
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Mar 07, 2008 | Uniden 5.8GHz Cordless Phone
Nortel CallPilot Manager
I think the best thing I can do is give you the link to the user guides so that you can pick the one most suited to your application, as Call Pilot has many facets ... Good Luck
http://support.nortel.com/go/main.jsp?cscat=DOCUMENTATION&poid=8165&viewOptSelect=3|1
Jan 16, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Electra professional nec
I am making the assumption that only line 1 has caller-ID. Both of my suggestions require services on the phone lines themselves, and not thru the phone system.
  1. Line 1 needs features on the line to allow three-way calling. Then you would hit the Recall key after answering to send a Flash to the Central Office to dial the 2nd number. This takes the transfer away from the phone system and puts it on the CO. This requires more time and effort on the staff answering phones, and if a calls comes in while this is in progress, it's going to roll over to another number in the hunt sequence anyway.
  2. Get Caller-ID on all lines.
Jan 11, 2008 | NEC Electra Professional ETW-16DC-2
NorStar M7324 Telephone Logo
55 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
