Question about Sewing Machines
How to grease the gears - Sewing Machines
  • Sewing Machines Master
  • 9,511 Answers
What make and model sewing machine do you have? Every machine has different needs as far as oiling/grease. Some do and some don't.
Posted on Apr 28, 2015
What does it mean when the machine shows a problem that look like entwined gears
if you mean twisted gears? then this is a sure sign that gears have slipped in there relationship to one another , its called gear timing , all the gears have "timing "marks on them to show how they go to next gear so that every function moves in a proper fashion and doest hit something else , if gears are out of time something made this happen ? (too thick fabric, wrong oil, wrong grease, or heat ) makes these gears fail as does plain worn out as well
Feb 25, 2016 | Sewing Machines
Sunbeam Sb 1800. What should I do to oil it?
there is only one place I oil this machine , and that's in the bobbin area , all the parts that move inside there could help with a drop or two of oil ,(not covered) the gears in the lower unit (bottom) should be greased once a year to prevent wear , Not any grease will do , as most car type greases will dissolve plastic gears found in these , use only grease safe for plastics , in fact its such a problem most mfg say not to grease them at all, just let em wear out and replace em
Feb 09, 2016 | Sewing Machines
How do i oil cub 3
1. The needle arm(rod attached to needle) and pressure foot arm. Use sewing machine oil.
2. Remove top. Use QTIP and rag to clean parts. Use silicon grease on gears and all metal against metal. Replace top.
3. Remove bottom. Use QTIP and rag to clean parts. Use silicon grease on gears and all metal against metal. Replace bottom.
4. Built up, old grease: Use carburator cleaner.
Feb 24, 2015 | Sewing Machines
Low gear
In that old a machine I suspect the grease and oil of the mechanism has gotten hard (waxy) and is causing the gear mechanism to stick. Most likely it simply needs to be taken apart, the old lubricant removed, and new grease and oil added.
Mar 23, 2014 | Husqvarna Viking 1
Singer 247
Have you greased the gears? Are they metal or plastic? Metal gears get grease, not oil. Try a really thorough cleaning. If all else fails, take it to a sewing machine repair shop.
Oct 25, 2013 | Sewing Machines
Singer Model 3116, I am doing some maintenance on this machine and there is no grease on any of the gears. Do these gears need greased?
here is a free manual from singer, look in it and see if it show about
oiling the machine, if it doesn't contact singer and see if the machine
is one of the self oiling machines
http://www.singerco.com/uploads/download/438_3116.pdf
Customer Service: 1-800-4-SINGER (1-800-474-6437
Nov 15, 2012 | Singer 3116 Simple
Balance wheel doesn't move needle
You really should clean and oil/grease the entire thing. Dust, lint, old oil and grease can harden making your machine not run properly. Another thing that may be causing you issues is dried up and gunked up grease on some inner gears. Take off as many access panels as you can and use a tooth brush to remove yellowed dry grease from gears, replace the grease with one made for sewing machines. Lightly grease... just a little dab will do it. Turn the machine by hand to work the grease around the gears.
Make sure it's out of bobbin winding mode. Do you remember if you had had to replace the motor belt or had to take the hand wheel off for some reason?
Take the hand wheel off and look for a funny looking lock washer (typically has ears on the outside of the washer and two fingers pointing toward the center of the washer that fits into two grooves) The two fingers are slightly angled... the angled fingers should be pointing OUTWARD when you put it on. This seems counter intuitive but it must be inserted this way for your machine to work correctly. Put it back together and see if it works.
I like to use Liquid Wrench for especially stubborn machines that have been sitting. Don't use WD40 it will free up rusty things but you have to wipe it down well and re-oil. Liquid Wrench is petroleum spirits (kerosene) and graphite, much better for the machine in the long run.
Good luck.
Nov 07, 2012 | Montgomery Ward Sewing Machines
The needle in my Viking 6440 is locked in on the left side and the machine will only sew in reverse. The reverse button cannot be moved in or out.
I'm trying to find a machine similar to yours and have done much research re: the older mech viking sewing machines 6000 series. They are GREAT machines, suffering only from problems such as yours caused by the old "lube/grease" they used when it was made @ factory. In their efforts of making a "never needs oil" mech sewing machine, the grease tends to harden & freeze up the gears & cams inside the machine. You need to have it serviced @ authorized Viking shop as you have to completely disassemble the machines & gears, clean, re-lube, & re calibrate the gears... I understand this s/b ~ $175. Money well spent considering if taken care of your beauty could be sewing for another 60 yrs!
Hope this helps!
Jan 22, 2010 | Husqvarna Viking 1
My zigzag broke on my Sewing Machine
Use white lithium grease on the gears, and sewing machine oil on the other ... or broken, get a replacement from your sewing machine supplier
Jun 26, 2009 | White Sewing 2037 Mechanical Sewing...
Where do I oil the sewing machine?
OILING
FACTORY LUBRICATED PARTS WILL PROVIDE YEARS OF HOUSEHOLD SEWING
WITHOUT ROUTINE OILING. HOWEVER, WHENEVER THE MACHINE tS BEING
SERVICED, CHECK TO SEE IF ANY PARTS NEED TO BE LUBRICATED.
OIL
APPLY GOOD QUALITY SEWING MACHINE OIL TO THE POINTS (A, B, C, D, E)
INDICATED BY BLACK ARROWS.
GREASE
WHITE GREASE IS RECOMMENDED FOR USE ON GEARS AND CAM SURFACES.
IT IS AN IMPROVED GREASE, AND IT CAN BE USED ON THE METAL AND PLASTIC
PARTS WHICH POINTS ARE INDICATED BY THE WHITE ARROWS (F,G, & H).
HOW TO ORDER
PARTS NO.
EM / 40M
DESCRIPTION
SEWING MACHINE OIL
WHITE GREASE
Apr 12, 2009 | Kenmore 15358
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
