Internal charge port came loose. Which wire goes where--red and black
The internal port where the charger plugs in came loose from its wires. I need to know where the red and black wire goes
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Google it and then click on and include the make/model of the machine and then click on images.
Posted on May 06, 2015
sandrew
  • 2961 Answers
SOURCE: Toshiba Satellite 5005-S504 3 USB Ports not functioning
I don't think a wire is the problem as they are soldered to mobo. It is more than likely a power problem. If you go to the hardware tab in device manager and go down to usb root hub>right click and properties then look at the power tab and you will see a 500MA allowance on usage. You can easily go above these if you are using them, so check that they are all active. Also go to control panel>admin tools>services and look down list for 'plug n play' and make sure it is set at automatic and 'universal plug and play' is set at manual
Posted on Jan 29, 2007
  • 72 Answers
SOURCE: DC power jack in Toshiba Satellite A65-S126 PC Notebook
Not that hard to fix if you are careful about taking it apart and re-assembling it. A digital camera is helpful during the dis-assembly to remind you later where everything went. Took me about 2 hours the first time I did one. Just take your time.
When your done, get a CRD (Cable Retention Device) to relieve the strain on the cable and the pin. I use one from this company.
Posted on Apr 25, 2008
hotkanni
  • 13 Answers
SOURCE: hp dv 2000 power switch wires 3
To know exact locations of the notebook inner parts, you can try the below manuals of DV2000. Hope this will resolve the issue.
http://h10032.www1.hp.com/ctg/Manual/c00729555.pdf
It is Service Manuals of your notebook model.
Posted on Sep 09, 2008
Geekman
  • 32281 Answers
SOURCE: power chord must must moved continually to show charge
Yes, this is common, if the power cord at the connector is flexed continually then the metal fibres in the cord will break due to metal fatigue.
You can cut off the connector away from the break and fit a new connector on the cord, make sure the the wires are soldered correctly to provide the correct polarity at the connector.
The problem could be at the laptop where the connector plugs into the laptop's power socket. It could have a dry solder joint or the socket is faulty. This requires dismantling to repair.
The HP warranty would cover the normal warranty period and would not extended for worn parts.
Posted on Apr 16, 2009
bogolino
  • 8 Answers
SOURCE: The charger port on the computer is loose how do i open the port
unfortunately you will have to open up the notebook, take out the hdd, optical drive, wlan card, ram card(s), motherboard, and under the mb, there will be your charger port. Recomandation: Don't try to fix it yourself, UNLESS you know what you are doing. If you don't just go to the local repair shop.
Posted on May 06, 2010
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
Car battery is dead. I have a Black and Decker Simple Start car battery recharger. I can figure out how to plug the outlet part into the wall but I do not know what to do about the part that goes onto...
You should have 2 wires with clips = one red that you clip on the Positive [ + ] post of the battery, this may be marked red on the cable. The other black clips to the Negitive [ - ] post of the battery.
Don't plug in the charger untill you clip the wires to the battery, make sure the charger is set to 12 volts. If your cherger has a cigar lighter wire just plug it in to the dash port.
May 09, 2011 | Honda Odyssey Cars & Trucks
ALL Voltages (three wires) iones battery of Ton Tom one
Not sure why you would need to know this , red is live black is return circuit and the yellow is auxilliary and usually goes to charge input. as a live wire It is easier to cut and graft a new battery to the stubbs of wire than to solder new battery on. What you might really be needing is the polarity.. whether any charge pin is positive or negative if you are making a new internal charge point. Consult the back of the charger it usually states the polarity in a graphic.
Jul 23, 2009 | Tomtom One XL GPS Receiver
The plug that connects to the alternator has three
Yes the White wire is the reason. It goes to the Internal Regulator.
As you view the connector that plugs into your alternator, look at where the lock tab is.
Lock tab on TOP. The Black wire goes to the Left side. The White wire goes to the Right side.
The Black wire, ties into the Red wire down in the wire loom. (The Red wire goes to the starter solenoid, and this is connected straight to the battery. This is why the Red, AND the Black wire, are both Hot wires)
The White wire goes through the bulkhead wire loom, and to the bulkhead connector.
(Down under the steering shaft, and on the firewall, you'll see a rectangular Black box shape, with a Bunch of wires, coming into it from the engine compartment. The bulkhead connector is two pieces. Following it through the firewall, the other side of it is the fuse panel)
Where the White wire connects in the fuse panel,
it should go straight to the ACC fuse. (Accessory)
May 15, 2009 | 1987 Chevrolet Camaro
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
http://tech.groups.yahoo.com/group/power-assist/files/EV-Warrior/
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
rick
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Something is either work my my charger or the phone for the lg vu. a few days ago, the charger worked fine but for some reason its ot working but the red dot on the charger is on; when i plug it to my...
It is loose now the charging port may have gotten broken. It happens with the LG VU's.
If this is the case, you have 3 options.
1. repair -warranty preferably
2. new phone
3 or external battery charger. cheapest option
Check out the following link for more information
How to Charge LG Vu with Broken Charge Port
Mar 07, 2009 | LG Vu CU920 Cellular Phone
MDA (i really need this phone to work, my fav. phone)
The freezer thing was a stupid idea. Maybe your charger is not an original charger? or if it is the charger port could be loose.
Sep 13, 2007 | T-Mobile MDA
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Computers & Internet Logo
David Payne
David Payne
