Question about Vizio Televison & Video
A possible fix for this Vizio TV?
Comment: I have a Vizio, Mod# E480I-B2 that is a source of frustration. If needed, here is the SN# LWZQPODQ2106565. When it works it is simply phenomenal, however it will not function on a regular basis. I have tried all of the reset hints and I've gotten nowhere. Is there a part that can be replaced to bring this thing back to life? Currently it is an attractive piece of plastic. Any help and insight would be very much appreciated. I purchased the TV in December 2014, it worked beautifully for about a week. The purchased was made online and will not bad mouth the company at this point...I'm really tired of thinking about them...maybe later. If I can get it to come on, everything is wonderful until it is powered off. At that point it will power up but will only show the dreaded "V" logo. It cannot be powered down or controlled in any way. Unplugging is the only option I have found. I have tried the hard reset 30 or 40 times with no luck. If the TV sits for approx. 7 to 10 days (yes days) it will power up and once again work beautifully. However, it will at some point power itself down and it's dead again. I've managed to keep it going for a couple of days by turning the cable box off and keeping the TV powered up. It will work for awhile but will once again go into hibernation. Surely this is not the only one with this type of symptoms. I truly hope you can help me find an answer before this thing becomes a stationary target at the closest gun range. Thanks in advance for your help! Kyle Revercomb
  • 494 Answers
Sounds like the flash memory has an error for the basic routine on power-up. This could be a faulty program write, error of the bios chip set or a bad memory capacitor if present. I think the cap is there as you have to power the set off for several days so it bleeds off.
Many electronics have a 'house' program for each TV set for the unit to run from start up. Not sure if there is an easy cure as the EEProm may have to be re-flashed. The start up program may have an error and with out a reset button this may have no solution.
I would suggest when it doea power up correctly, power it down and unplug for several days, then restart it.... do this several times and the re-boot may correct the fault.
Posted on Jun 30, 2015
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
  • 92 Answers
SOURCE: Black showing as red on LCD
this is a LVDS cable issue. All you have to do is call Vizio and they will send out a tech and replace the LVDS cable along with the Main Board. This should resolve the pixilation issue.
Posted on May 20, 2009
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
Best picture setting?
It will depend upon your viewing taste.
Jan 12, 2016 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
How can I fix ? where do I get parts ?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 08, 2015 | Vizio Televison & Video
Volume goes up and down at will
Incedental lighting can affect the IRD receiver module on the front of the TV. Try blocking all source of energy with black tape to prove this. If no effect then you may have to reset the TV or reprogram the input device, cable, on air etc....
Jun 29, 2015 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
Best picture setting for vizio E480I
Go to the main menu and find settings. You can set the default screen parameters there.
Keep in mind that there are still channels which are not yet providing HiDef video to carriers,
Dec 19, 2014 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
Where is the serial # located on the vizio hd smart tv
It can be noted at the back cover of the TV; or at its chassis inside.
Electro help
Nov 24, 2014 | Videosecu TV Ceiling Mount for Vizio 23 24...
VIZIO TV SAYS INCORRECT CARD
IF YOU HAVE CABLE CARD FROM COMCAST OR OTHER CABLE COMPANY CALL THEM AND LET THEN THE CARD IS BAD Colorvision Services
Oct 26, 2014 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
Televison & Video Logo
78 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
