0382,0391,0320. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Paktech rm 303e remote controller should ba a so called "universal remote"
Look up in it's manual the code for your DVD. If not there, follow directions for unknwn cde.
If still can't turn on your DVD, you should look for another remote or buy the proper remote of your DVD
SOURCE: Remote control RM-810
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching
1. Turn on the TV
2. Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once.
3. Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on.
4. Release both buttons. The indicator light will flash constantly indicating the automatic search mode.
5. After the indicator light illuminates, release the two keys simultaneously.
6. If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller
7. Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
SOURCE: I've got a Telefunken Vegas
Hello
Telefunkent cannot be programmed with this remote control, either by direct code entry or by code search. OK.
SOURCE: Does anyone know the codes for operating an LG TV using the JVC RM-STHM303U Remote Control?
Codes for LG Brand TVs are: 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
