Question about 2014 Range Rover Sport
Range Rover sport 2014 3.0d. Airbag light's on.odb code-b0028 right side airbag deployment control.any solutions guys? Thx
  • 268 Answers
It should be a simple diag, as that fault indicates a short circuit between two specific wires, which just needs to be found. Dealer shall try to find it which wires in the areal of the trouble code.
"RF/Passenger Side Deployment Loop Resistance Low"
Posted on Jan 02, 2016
  • 184 Answers
SOURCE: airbag light keeps flashing
HAS UR AIRBAG ECU BEEN REPLACED I KNOW SOMETIMES NEED TO BE REPLACED AS WELL.
Posted on Feb 10, 2009
emissionwiz
  • 76630 Answers
SOURCE: airbag light stays lite
Unfortunately, the only way to reset the lamp is to clear the trouble code with a scan tool. For issues like low battery voltage, the lamp will go out on its own after a predetermined number of key cycles without detecting the problem. You could try driving it for a couple days to see if the lamp goes out before taking it back to the dealer. But be advised that the air bag system may not function properly while the lamp is on.
Posted on Mar 23, 2009
  • 335 Answers
SOURCE: Our Airbag light is lit up on the dash of our 2001
When the air bag light is on, the system is not operational. Please have your dealer look at this ASAP.
Posted on May 01, 2009
  • 323 Answers
SOURCE: driver's airbag light on 2007 PT Cruiser convertable
The first code is for "driver seat track position sensor low". The module detects that the sensor input is less than or equal to 0.3 mA. The second code is referring to the first code. I have no idea what the third code is. Basically you have two different communication systems mixed. The 2001 uses the PCI bus system and the 2007 uses the CAN bus which is much faster. The first code is a CAN bus code and the second is a PCI code. As far as the airbag deploying in the event of a collision, I don't believe it will with an active code in the system. I hope this helps.
Posted on May 13, 2009
co7196
  • 3433 Answers
SOURCE: '96 Saturn airbag light, do I need a reset or just drive cycles?
whomever changed the parts hasn't finished yet. Go back and tell them so. Or tell them the light is on so the parts they put in need warranty replacement. Good Luck
Posted on Jul 26, 2009
My airbag light on the driver side goes off and on and chimes every few seconds on my 2007 Pt Cruiser. I'm afraid if I drive it with this happening my airbag will deploy on me.
The warning light means that a fault has occurred in the Airbag system (known as the "SRS" system), when this light is on the SRS system is disabled, so no the Airbag can't go off because the controller module has turned it off completely. Get it fixed ASAP because right now if you have an accident your SRS system will not work (Airbags will not deploy) to save you from injury.
Jul 15, 2016 | Cars & Trucks
Airbag light comes on
You would need to have someone scan the body computer to get the trouble codes for the air bag system.
Sep 21, 2012 | 2006 Land Rover Range Rover Sport
How can I remove the driver's side deployed airbag on my 2005 saturn Ion 3?
The Airbag is held to the steering wheel by screws at the back of the steering wheel, remove them and disconnect the electrical connector to the Airbag. Also whenever an Airbag is deployed the Airbag control module must be replaced, they are a one deployment part and then thrown away.
Apr 10, 2011 | Saturn Ion Cars & Trucks
What does abs fault mean ?
Their is a fault with the electronics on the air bag circuit. This will bring up the airbag light, you will need to see a dealer with an electronics reader to find out what this fault code is meaning. Most dealers will read it for free, and then charge for the repair from that point. If it is an orange light, just get it to a dealer when you are able to. If it is a red light, avoid driving it and get to a dealer ASAP. this will prevent any possible electrical damage and ensure the airbag will operate correctly if it has to be deployed. You have to be very careful working around airbag systems, their is a loaded charge in there and will go off like a shotgun if incorrectly tampered with. This could cause serious injury. My strong advice is to see your mazda delear as they will have the tools and expertise to diagnose and repair correctly. Good luck, let me know how you got on!
Jan 29, 2011 | 2000 Land Rover Range Rover
I started my 07 escalade esv in the morning about 1 weak ago and the service airbag light apeared and i was hoping it wold just go away in time but it dident i have about 120.000k in the car any cheap...
its better to go to service center and diagnostic tool will tell you which of your sensors or airbag module have the problem, i wish that no deployment happen because if deployed is commanded you will change the airbag main control module, repair acording to the dtc codes and diagnostic aid, if the problem is module such as side airbag, curtain, drivers airbag or the passenger airbag, you may connect the two wire by 2.2 ohms resistor 2watts. if you want little cost but the disadvantage is, what ever happen in your car, there is no airbag deployment even the computer will command to deploy in case of accident, my suggestion to you is not advisable but its about you
Jun 26, 2010 | Cars & Trucks
1994 Buick regal gran sport coupe did not come with a passenger
NOt an expert but my guess is no. First an airbag uses essentially a powder charge to deploy the airbag. Installation and removal is not recommended for joe shade tree mechanic,it can be dangerous. Secondly all that installation has to have a place to mount and a spot inthe dashboard through which it can deploy. Chances are it if didn't come with one an airbag would have no place to "live". If it is even possible to have it done it would probably approach 50% of the value of the typical car that age. Good luck.
Sep 07, 2009 | 1994 Buick Regal Gran Sport
2005 Range Rover HSE - Air Bag Trouble light on !
Airbag resets need to be taken to the dealer or someone with access to the right diagnostic equipment(unlikely) Store bought code readers will not work.
Jul 08, 2009 | 2005 Land Rover Range Rover
Rear air bag on my 1998 range rover is not attached
Since your vehicle is a 1998 your struts(possibly springs) are going bad just because of age and ware & tear over time. I'd reccomend taking this to a mechanic to have them check out your suspension, generally new struts and springs all around will cost 300-400 for parts, and a few hours labor. It can be easily done by yourself as long as you have a spring compressor. If you don't have a haynes manual already I highly suggest purchasing one for your car, most auto parts shops have them, and you can find them on ebay pretty cheap.
You can most likely replace the airbag yourself if you get a new rear airbag and install it yourself, but remember to disconnect all of the battery terminals so that the car does not for any reason deploy the airbag while your working on it(very unlikely) but its a good saftey percaution. Personally I would get the rear airbag professionall installed because I'd want to be 100% sure it would deploy in case of an accident.
May 24, 2009 | 1998 Land Rover Range Rover
Driver's airbag light on 2007 PT Cruiser convertable
May 13, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
2014 Range Rover Sport Logo
205 people viewed this question
Top Land Rover Vehicle Parts & Accessories Experts
Dan Shibata
Dan Shibata
Bill Boyd
Thomas Perkins
Thomas Perkins
Are you a Land Rover Vehicle Part and Accessory Expert? Answer questions, earn points and help others
