Question about Sharp Office Equipment & Supplies
Sharp MXB-201D copier bad quality copying from top and glass, but good copies when coming from computer. Fan runs long time after a copy is made. WHat is wrong?
  • Sharp Master
  • 6,161 Answers
Check the CCD, which is what see the image on the glass, have a tech check it out
Posted on Jan 30, 2016
  • 163 Answers
SOURCE: Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Posted on Sep 16, 2007
  • 62 Answers
SOURCE: SHARP AR-507 DIGITAL COPIER
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Posted on Dec 13, 2007
SOURCE: Sharp AR-285 reporting code F2 and smeared copies
to find the sub code press start key,if it shows 04,then ic chip present in it gone bad,replace the toner ic chip.
Posted on Apr 23, 2008
frankzjm
  • 191 Answers
SOURCE: poor copy quality
there are 3 reason if the copy gray & less sharp:
1) the toner you are using is not compatible very well with the cartridge unit if you changed other compatible toner.
2) the cartridge going near the life-cycle, (also cause print blurred)
3) the photo drum going near the life-cycle
you may try to change the quality toner (original factory). or
change the cartridge if it is out of the life-cycle
Posted on Jan 23, 2009
Sharp Tech
  • 63 Answers
SOURCE: Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Posted on Oct 17, 2009
Print quality is batter but copy quality is not batter horizontal lines come in copy
Clean the glass for the scanner. If you get lines only when copying usually it is dirt. If your copier has both an adf and a flat glass for scanning, scan from both and compare the quality.
Dec 16, 2014 | Office Equipment & Supplies
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
When copying we are getting 2 lines down one side of the copies
Only when copying? What about printing? There are a couple possible causes. The easy one to check for is to make a copy by laying your original on the glass. Now make the same copy using the automatic feeder on top. If the feeder copy has the lines but the glass copy does not then the problem is coming from the ADF scanner glass which is the thin strip of glass that is just to the right of the large main glass. If so then just clean the strip of glass with a soft cloth and some glass cleaner. Note that sometimes the stuff that might be stuck to the glass is hard to get off. If BOTH the ADF copy and the main glass copy have the lines then most likely the lines are coming from the drum unit. If you have the copier hooked up for use as a PC printer then does the print from the computer have the lines as well? Then it most definately is coming from the drum unit and you would need to replace it. If the PC prints are clean then the drum is not the cause.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 28, 2010 | Sharp AL 1631 Copier
Our Sharp AR-160 copy machine is 5 yrs old. We have had to have continued maintenance, most recently the "developer" was replaced and our copies still come out faded. How long should we expect...
Did they clean the laser unit?
You can play with bias to raise the copy darkness.
For start you can open the front door and right side way door, remove drum unit, and you will be able to see long glass above drum unit. clean it with the dry wipe or wet one but be sure to dry it.
By my experience it is a good low maintenance copier... if the preventive maintenance is carried out correctly, every 60 000 copies more or less.
Hope that helps!
Dec 27, 2010 | Sharp AR-160 Copier
Sharp AR168D won't copy
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
Mar 31, 2009 | Sharp AR-235 Copier
Copies have black lines on them after i replaced the toner
does the lines come when doing copies in the doc feeder only? or on the glass also?
if only in the doc feeder lift up doc feeder and clean the small strip of glass
Oct 30, 2008 | Sharp AL 1631 Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Line on copy
You have a small dot on your scanner glass. Lift the lid and check the thin piece of glass on the right side of the machine. The smallest piece on the glass will cause that. Clean if with some windex and a cloth and the problem will go away.
Jun 30, 2008 | Sharp AL 1631 Copier
Sharp AL-1340
Try this: make a copy from the table and then one from the document feeder. compare the two. If the copy from the table looks good and the document feeder one is bad then clean the glass on the document feeder. If both are bad remove the top glass and clean the mirrors using rubbing alcohol and a lint free cloth. you can also clean the wheels on the feeder and in the tray with rubbing alcohol if you ever have feeding problems
Hope this helps
Apr 12, 2008 | Sharp AL-1641CS Laser Digital Copier
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
