Question about Breville Irons
Where can I get a plastic water cover for a Beville vin213
The water leaks out due to the plastic plug not closeing as the lug is broken off it
Cracked water window
this is due to low quility of metal which is damaged use some water unreacting metal.
Jan 23, 2014 | Philips Irons
My wifes Hamilton Beach Iron model 14977Z leaks water from the wall plug where the prongs are molded to the plastic. She told me about this and I said impossible, but she proved me wrong. This can be...
If this question had come through yesterday I would have said it was an April fools joke. Somehow pressure is leaking back into the iron body and the only outlet it can find is some poorly made electrical lead. For starters I suggest that you replace the cord and plug. Perhaps a better quality cord will not do that. For extra security, seal the ends of the wires with silicone sealant. If I had grand kids, this would be a story to tell them, like you say, it is hard to believe but good luck.
I just told my wife the story and she asked if the water was not coming from the wall socket from a leak somewhere else in the house?
Apr 02, 2011 | Hamilton Beach 14977 Iron with Auto...
It is leaking water when ironing all the time to the point that it stains the clothes
Remove the top part and check for the leak. If plastic has been damaged then you must use some good bonding material to close the gap/leak. However if the leak seems to come from over filling , redduce level of water, or from a gasket on the filling part.
Please look carefully into this in the ironing position with the power OFF.
Hope this helps . Good day
Aug 18, 2010 | Rowenta Perfect Iron
Good day I have an euro pro iron and it leaks all the time leaving water on washed clothes.also it leaks out of the bottom??
The water may come out at the bottom instead of steam. this is due to insufficient heat produced. So switch on your ironbox and keep it in full temperature using the knob. then the water will be coming out as steam and not as water itself. Try again.
I hope this is useful to you
Thanks
Jun 27, 2010 | Sunbeam Euro Press 4045 Iron
NO STEAM COMING OUT....IRON IS HOT AND WATER IS HOT, BUT PUSH SWITCH FOR STEAM??NOTHING COMES OUT
you need to use a descaler, the holes have become clogged. you can buy this in most hardware stores
Mar 23, 2010 | Rowenta DG-980 Iron
My Oreck Cordless Iron leaks constantly. What can I do to stop the leaking?
Find where the leak is coming from, and coat the leak or crack with silicone.
Jul 29, 2009 | Oreck Cordless Speed JP8100CA Iron
Rowenta model 1700W. Water leaks out front of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 23, 2009 | Rowenta DZ1700 Iron
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
No steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Jul 09, 2008 | Rowenta Steam Generator DG050 Iron
LEAKING IRON
This was happening with mine - leaving trails of water behind as well when I ironed. I took it all apart (figured it was already broken, what could I do worse?) I discovered that there is a rubber gasket around the hole that lets water move from the reservoir to the heating plate. The two surfaces (reservoir and plate) are held together by screws, which compresses and seals the gasket. The bottom surface of the reservoir section had been cracked (due to a drop on the cement floor, probably, and the two surfaces could no longer fit tightly together, the crack allowed it to flex, and water leak out. In other word, once it's leaking like that, it's time for a new iron. Sorry I can't offer a fix, but at least a explanation!
Jun 25, 2008 | Rival IR600 Iron
Irons Logo
87 people viewed this question
Top Breville Irons Experts
ray gallant
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
