Question about KitchenAid KDTE404DSS 24 6-Cycle/6-Option Dishwasher, Architect
Drainage-won't drain Grey Water stays in bottom of tub, Does not appear to be any blockage in filter
    New Friend:
    Problem Solver:
  • 15 Answers
Check the dishwasher drain line, it may be clogged. You will probably have to pull the dishwasher out from under the cabinet to remove it and check it fully. If it still doesn't drain, it is then probably your drain pump. I just replaced one of these and it was pretty easy. I bought from appliancepartspros.com because of their good return policy and prices. They can also help you diagnose your problem.
Posted on Jun 08, 2015
Model EDI97170W code error E20 appear on the LCD panel.. is means for
An Electrolux?
The E20 fault code means there is a blockage in the drainage system of the machine.
Check the drain hose, the laundry sink tub and also the pump filter at the bottom right hand side of the washing machine on the front of the cabinet. Pry the door open, undo the filter bung and clean out the pump housing ok,
One of these is blocked and it is restricting the flow of water when the machine should be fully drained before spinning.
Dec 04, 2016 | Washing Machines
How to clear a blockage in the drainage tube from the soap dispenser to the tub?
best to take the top off by removing the bolts in the back the slide it to the back then off.you then can get to the hose and remove it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 04, 2014 | Samsung Washing Machines
My washing machine won't spin. i've cleaned the water hose filter and the pump filtre.
Hi eddyloz2000,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Washing Machines
Dishwasher completes programme but does not pump water away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 13, 2011 | Bosch Dishwashers
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
Will not empty water, and stops before end of cycle. Doesn't appear to be any blockages. Filters have always been in place, and appear clean on inspection. No twists or sharp bends in drainage pipes.
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jan 25, 2010 | Bosch Dishwashers
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
E20
Could you hear if pump is working ? Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port.
Nov 19, 2006 | Zanussi ZWF1230W Front Load Washer
KitchenAid KDTE404DSS 24 6-Cycle/6-Option Dishwasher, Architect Logo
129 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
