Won't DRAIN - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
Washer will not drain:
My advice is free cuz God is good!
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity
Posted on Apr 29, 2015
Water won't go down drain.
It appears that you have a drain pipe problem. Check that the hose is not restricted ( kinks etc) Get a good drain cleaner that you can use in you machine and clear the gunk out of the hose. Contact simpson dealer for a compatible product to do the job as some drain cleaners react with the steel and hoses.
May 06, 2013 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Why won't the aircondition drain won't drain
If you are saying the ac is dumping water into the cabin floor, the drain tube is probably stopped up. The tube should be under the car near the passenger's feet. You would insert a coat hanger or other stiff object to clean out the tube.
Jul 03, 2012 | 2005 Chevrolet Cobalt
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
