Question about Vizio SV471XVT 47 in. LCD TV
How do i fix my vizio sv471 xvt tv. black screen, smells like something is burning
  • 494 Answers
Possible back light power driver is faulty or shorted. New drivers can be had on Ebay but not too cheap.... Simple to install!
Posted on Jun 30, 2015
rapanSF
  • 150 Answers
SOURCE: vizio 47 xvt.audio comes on but no video.no response to remote.
So power button on TV and remote control doesn't turn it off? May also be set on mute and remote battery needs changing.
Posted on Dec 21, 2008
circuitworld
  • 335 Answers
SOURCE: I have the 47
First check your settings options on how the tv handles HD signals. the settings determine how fast the transition periods are when sampling pixels interlaced or progressive. Be sure the tv is on auto-set for 420p-1080i input signals.
if the problem is still there:
Yes, try using a better grade HDMI cable with better impedance characteristics. this is a good idea anyway but probably not the cause of this problem.
Check the software compatibility between the tv's media input devices and the tv. The tv software may need upgrading and your cable provider should do this for you as well as the manufacturer of the tv.
for more help contact us:
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
CWR-on_line Tech Rpt
Posted on Oct 29, 2009
  • 3 Answers
SOURCE: Hi there-I just hung a
check the screws that you used to install plate on the back of tv some times they are to long ,it can be pressing up against circet board with out you knowing
Posted on Nov 02, 2010
welcomejee
  • 10594 Answers
SOURCE: I have a three year
Take off tv back and observe power supply board and back light inverter board for burn spots, replace that board that has burn spots.
Power supply board is where AC cord goes in and inverter board would be installed at side of lcd panel. Required board would be available in discount-merchant.com
Thanks.
Posted on Aug 16, 2011
ladywinn
  • 5138 Answers
SOURCE: Vizio 42 in. Black screen no sound. TV will not
Look on Shopjimmy.com for Parts. Look on power supply for Bad Capacitors they will be swollen or vented on Top.
Posted on Oct 18, 2011
How do I fix my VIZIO TV?
Vizio TV Repair - Instructables
www.instructables.com/id/Vizio-TV-Repair/
InstructablesSo my Vizio TV was flashing on & off rapidly every time I switched it on. ... good way to get something to work, but it got things working until I had time to repair it.
Fix Power Problems In 5 Easy Steps: What To Do When ...
vizhdtv.com/fix-power-problems-in-5-easy-steps-what-to-do-when-your...
Aug 26, 2015 - Vizio TV power cord plugging into a power outlet. Do you know ... Powerproblems might require service or replacing parts inside the TV. Before ...
Dec 14, 2015 | Vizio E-Series E470I-A0 47" LED TV...
Need code for 7 blonks on power button
www.ask.com/
www.wikipedia.org/
www.infolinks.com/
www.info.com/panasonic_viera/plasma/tv/th42pz80u/blinks/7_times/and/black/screen/mean/
most likely failure of module in the tv, most likely fuse, capacitor, something burn up, find the air vents smell the area your smelling something burn up smell, if you have every smell electronic stuff burning up you will understand what i mean you will never forget that smell.
Oct 06, 2015 | Panasonic Viera TH-42PZ80U Plasma TV
TV powers on and goes black.
first i'd say try all the normal things...
swap sources, check to see if the osd comes up, etcetera. it might just be that the tv isnt receiving a signal from the source its tuned to. see if theres a way to factory reset the tv, try it.
if no matter what you do nothing shows up...
maybe the backlight burned out or maybe something on the mb burned out. go over and sniff the tv, notice any smell? if this is the case, i dont suggest trying to fix it new screen.
Jul 06, 2015 | Sony KDL60EX700 60 in. TV
I was wondering if someone could help me find which board could be bad on a Samsung PN59D8000FFXZA plasma TV.
look on the power supply board for burned parts. The board that controls the back light may have some burned parts as well.
Jul 05, 2015 | Samsung PN59D8000FFXZA - PN59D8000 59 3D...
My vizio 42 inch just made a very loud pop and the screen went black (off), the vizio leters at the below the screen stayed lit white as if the tv was still on. 5 minutes later a very loud pop then came...
Is it possible that it was storming when this happened? It could have been a power surge. If you are still covered under the manufacturers warranty, you should give them a call. Even if you aren't covered it wouldn't hurt to call to see if they can help or offer a discount to have it checked out and/or fixed.
Oct 04, 2014 | Televison & Video
I have a 55' Vizio Tru LED model VF552XVT. The TV ran fine for a year and a half and just recently the screen started shutting off after a few hours. I am aware that there is an issue where Vizio
It sounds like an overheating issue with the T-con board. You shouldn't have to run a house fan behind the TV to keep the screen on. Make sure you have the TV in a place where there is enough space around it to allow for air flow. Also, check to make sure the ventilation slots on the back of the TV are not blocked with dust.
Aug 30, 2012 | Vizio VF552XVT 55" inch Class XVT Series...
Vizio 47 xvt.audio comes on but no video.no response to remote.
Dec 21, 2008 | Vizio SV470XVT 47 in. LCD TV
Cleaner
Pretty sure you aren't supposed to use any chemical cleaner. I just use one of those pieces of fabric you are supposed to clean your glasses with and it has served me and my VIZIO XVT very nicely! But don't wipe to much because you can damage the pixels and screen. Gently. Hope that helps
Oct 24, 2008 | Vizio L37 Television
Vizio SV471XVT 47 in. LCD TV Logo
143 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
