Question about Cadie Ultimaxx U-4GT 3 Wheel Push Cart
I am in need of a replacem part. the 3 screw harnis attached to the cart that holds the wheel broke .
I need replacement wheels for my Tour Tech golf cart.
see the links
Spare Parts ' Spin It Golf
https://spinitgolf.com/t/spare-parts
Spare Parts. Spare Parts - Push Carts · Spare Parts - Electric Carts · Details. Battery Wiring Connection. $14.95. 6 Reviews. Details. Universal Remote for Easy Trek (digital). $39.95. 1 Review. Details. Anti-Tip Assembly ... Details. Front Wheel. $29.95. 3 Reviews. Details. Replacement lid for Easy Fold handle compartment.
Replacement Parts for your Golf Push Cart - Sun Mountain
https://www.sunmountain.com > Home > Golf Products Apr 15, 2016 - Sun Mountain offers replacement parts, how-to videos and customer service support for its popular line of golf push carts.
replacement wheels Search Results - Worldwide Golf Shops
https://www.worldwidegolfshops.com/replacement-wheels/search A partial match was found for replacement wheels. Show: Recently Added, Top Rated, Price Low to High, Price High to ... Online Only Callaway Trek Push Cart. 'False'. Callaway Trek Push Cart $199.99 ... Online Only JEF World of Golf Lightweight Steel Deluxe Push Cart. 'False'. JEF World of Golf Lightweight Steel Deluxe ...
Golf Push Cart Accessories ' eBay
www.ebay.com/bhp/golf-push-cart-accessories BONUS! New Clicgear 3.5 Golf Push Cart + Extra Accessories! White 3 Wheel Pull. $229.00. Buy It Now. Free Shipping. We face enough adversity and distraction during a round of golf as it is. It is vital that our equipment be one of the things that we don't have to think, or worry about. Find out why these current an.
Mar 12, 2018 | Golf
A chrome piece (1 of 4) on the front grille broke off on my 2005 Kia Sportage. I need to remove the grille to get access to the screws that attach the chrome piece.
Hi there my name is Brandon I am a mechanical n electronic engineering technician I am the man reg mechanics call when they cant fix something it may have a spring you may have to push both side in to get it out some are a pain
Feb 02, 2016 | 2005 Kia Sportage 2.0
Need to talk to someone about the cart
How new is it and did you haul something heavy in it? They are not made for weight.
Jan 09, 2016 | Rest-n-Roll Deluxe Folding Shopping Cart...
. I need to replace the ignition switch on my 1995 g20 sports van
This could be a challenge for a novice so if you don't feel comfortable with your ability, seek help from a trusted shop.
You will need some special tools to get the job done. Steering wheel puller, lock ring tool, phillips screwdriver, torx bit #30, flathead screwdriver, sockets/socket wrench, snap ring pliers.
First thing is to take the neg. battery cable loose. The airbag is located on the steering wheel and attached with 4 #30 torx headed screws from the back side. Remove and unclip the airbag and horn connections from the module. Remove the steering wheel nut with the 13/16 socket wrench or equal. Affix the steering wheel puller to the steering wheel--remove same. Affix lock ring removal tool and depress lock ring. Remove snap ring from base of lock ring on steering shaft. Remove 2 phillips head screws from lock ring located at approx. 11:00 o'clock and 7:00 o'clock of the lock ring. Remove lock ring.
Now remove the turn signal switch. It is attached with 3 phillips screws. There is also a small phillips screw holding the turn signal indicator lever in place. remove the screw and bracket on the indicator then remove the 3 screws holding the switch. The turn signal switch should be able to be pulled out enough to access the screw holding the ignition switch in place. Don't get too aggressive with it but gently pull it out enough to get in there.
On the right side if the ignition pot is a couple of copper contacts that are in a plastic holder. These are for the buzzer that tells you your key is in the ignition. It pulls straight out with little effort. Locate the screw and Remove--it will be about 2-3 " long and it is what holds the ignition switch in place. You should be able to pull the switch assy. out of the column at this point. Replace with new switch and reinstall the holding screw. put the contacts back in if you want it to buzz when you leave the key in or have it on ACC. It won't hurt anything if you leave it out to avoid the buzzer.
Reinstall everything as removed making sure to put the steering wheel back on straight and tighten nut to proper specs.
You can rent the special tools needed most of the time from auto parts stores, see them for the details or conditions-(Auto Zone, Advance, O'reilley) just to name a few that have loan-a-tool.
Dec 31, 2015 | Cars & Trucks
Where do i find replacement casters?
That type of caster is widely available in bigger hardware stores
Aug 10, 2014 | Mainstays Deluxe Laptop Cart, Black
Given a hand me down Dexton Lil Driver Battery Golf Cart. Is there an online manual to find out what the charging cord looks like & where to plug it into the cart.
To charge... you need to remove the seat. Only 2 screws holding it in place. Underneath you will see the battery...you will notice wires from the battery connect to wires from the motor on the wheels...pull apart those 2 connectors and attach the charger...then plug it in to a wall socket and leave connected for a long period of time. I don't remember how long it takes for a full charge...but I'm thinking at least 12 hours. If the battery doesn't hold a charge you can typically get it at walmart or online. Best of luck.
Jan 30, 2011 | Toys
Installation of horn contact and steering wheel on trans am. Car is a 1981
Pull the horn cap off, it should have plastic tabs that lock into a metal cylinder underneath, but will pop off pretty easily. That metal cylinder should be held on by 3 screws. Under those screws is a plastic washer and your contact ring. If you're replacing a steering wheel and need to pull the old one buy, rent or borrow a steering wheel puller. There's nothing worse than having to explain to your buddies how you broke your nose removing a steering wheel. They puller looks like a crows foot. It has three slots on one side and one on the back side. You can use three bolts to attach it to the steering wheel. I wrench will work to screw down the large bolt in the center and the steering wheel will come right off. Put a new steering wheel on, new contacts, and you should be set to go.
Nov 10, 2009 | 1979 Pontiac Firebird
Abs light is constantly on in my 1999 daewoo lanos i think the abs censor is broke need to get a new one but dont know were to get acheap replacemeent any ideas
There are 4 wheel speed sensors, plus other things that can turn on that light. There are no "cheap replacements", the cheapest thing to do is to pay a shop to properly diagnose it and replace whats bad. That will be cheaper than guesiing and replacing uneeded parts.
Nov 09, 2009 | 1999 Daewoo Lanos
Front wheel plate snapped in two
http://www.janeusa.com/
mail them or call them for distribitor near you or sell direct.
hope they are better then grand names I owned. Same strugle always.
If not, then get inventive at a DIY store like me.
I used a vice, drill ,plate, bolt and screws etc to repair my kiddie carts years ago. The best one was the cheapest from a discount supermarket which survived everything, still use it in fun parks.
Don't forget to rate me.
May 06, 2009 | Jane Powertwin Azulon Stroller
Cadie Ultimaxx U-4GT 3 Wheel Push Cart Logo
651 people viewed this question
Top Cadie Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Cadie Golf Expert? Answer questions, earn points and help others
