Question about Flotec FP4875 Shallow Well Jet Kit
My box missing oring that goes between pump and this parts housing. What size is oring, maybe able to get locally. Thanks Eddie
Need oil filter size for a 2000 ford expedition, eddie bower edition
First, it's an Eddie Bauer Edition (says so right on your truck).
Second, if you call ANY auto parts store, they will look it up for you, and probably even sell you one! (If they couldn't find it before, maybe it's because you misspelled Bauer!) ;)
Jul 21, 2014 | Cars & Trucks
Why is the pump pulling water but blowing air as well as water in the pool?
look for small crack in strainer housing or missing o-ring on cover , i use a eye dropper of blue dye on outside !! of strainer housing , a quick look at pool return and you'll see where the crack is , dry out housing 1st but superglue has saved many a cracked strainer from replacemnet
May 08, 2014 | Pentair "Pentair" In Ground Pool Pump ...
Steamer Leaks
Maybe you can try your local car parts shop. You should find one that fits just right.
Most probably that it uses an oring from a car.
Nov 22, 2013 | Saeco Odea Go
Idles rough
My 0996 eddie bauer explorer did the same thing i replaced mass air flow egr etc nothing worked i finally figured it out there is a tube running from the egr mount that goes into the plastic houseing on you intake manifold there is a rubber o ring in there i pulled the tube the oring was broken put in a new one and now everything runs perfect. ps there is a hidden nut under the first nut of the dipstick mount that holds the bracket in place you need to gert that off to get the tube off not to much fun took me an hour hope this helps
Nov 14, 2012 | 1996 Ford Explorer
My power steering pump is leaking, need to know what size o-rings go on it?
Normally buy a box of orings all sizes sure too get suitable o rings in it
Nov 01, 2017 | 2000 Dodge Durango
What is the spark plugs gap size for a 2006 expedition Eddie bower
Without the engine size I would only be guessing.You can call your local auto parts store and they can provide you with the information that you are requesting.
May 10, 2011 | 2006 Ford Expedition
I have a lionel automatic ore loader(6-12712) with no directions as how to assemble it or how it works. i did get it together using the pictures on the box,but have a tiny spring left over-no idea where it...
I know this is more than 2 years late, but if you still need the directions to the ore loader, I recently acquired a broken ore loader at a garage sale. While most of the parts were either broken or missing it did have a complete set of instructions I would be happy to scan and email.
Apr 11, 2010 | Toys
My 1994 Hinda Civic CX appears to be leaking oil from the distributor housing...what do youu suggest in troubleshooting my problem?
If it is coming from inside the distributor it is an oring inside the distributor. If it is coming from around the outside it is a shaft seal. Remove the distributor either way, The internal oring can only be fixed by replacing the distributor, the external one can be replace by requesting it at the local parts house.
Sep 26, 2009 | 1994 Honda Civic
Missing part for eddie bauer car seat
CONTACT THE COMPANY and do not use a defective car seat EVER. See if it was part of a recall.
By Phone: 1-800-426-8020
By Mail:
Eddie Bauer Customer Service
P.O. Box 7001
Groveport, OH 43125
Aug 18, 2008 | Eddie Bauer Baby Gear
Replace parts
call 18005441108 -- they will provide you with any replacement part needed -- just have credit card ready!
May 07, 2008 | Eddie Bauer Musical Rocking Bassinet...
Flotec FP4875 Shallow Well Jet Kit Logo
89 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
