Question about Briggs & Stratton Measuring Tools & Sensors
I have a Briggs & Stratton intek 26hp. 445877-0760-E1. I am replacing the sump gasket. I can't seem to find the torque and sequence to put the sump and upper engine together.
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
  • 583 Answers
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Posted on Oct 25, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
  • 395 Answers
SOURCE: Briggs and Stratton Intek V
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
Posted on Sep 17, 2010
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
When replacing the crankcase gasket on a Briggs & Stratton INTEK engine should a gasket sealer be used on the gasket?
NO, just be sure that both surfaces are very very clean and free of oil.Put the gasket on and tork it to the specified tork then go get a cup of coffee, then come back and check the tork again. Good Luck and hope this helps you.
Jul 03, 2014 | Briggs & Stratton Briggs Stratton Intek V...
18.5 hp Briggs & Stratton putting in rocker arms back, one goes in to far?
turn the crank see if it rises back up you may have droped one of the guides that ride the cam because youll have to tear her back down
Nov 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a craftsman lawnmower with a 24 horse intek motor with the 4 screws holding air filter. it has started leaking oil at base of the left jug. it is leaking right at the bottom of it so i cant see...
I am assuming you are calling the cylinder the jug on the engine. If you think the engine is leaking oil from the cylinder you have to replace the crankcase. The cylinder does not separate form the crankcase as they do on atvs. If you see the leak at a gasket, it could be a blown head gasket, valve cover gasket or a sump gasket. The sump gasket is the gasket between the crankcase and the sump. The sump is the part of the engine the mounting screws thread into. The valve cover gasket is between the head and the stamped steel cover. Replacing the valve cover gasket is easy. Just remove the four bolts to remove the cover. Then clean the old gasket off. You can apply a thin layer of rtv to help seal the valve cover. The head gasket is between the cylinder and the head of the engine. If this gasket fails, the engine can burn oil and/or leak oil. The head gasket is more involved to replace. You need a set of feeler gauges and a toque wrench to do the repair
qf8hqfvfwspt07waaaaasuvork5cyiia
Oct 25, 2017 | Briggs & Stratton Briggs Stratton Intek V...
123602-0131 BRIGGS & STRATTON ENGINE. NO LOW SPEED BELIEVE IT'S THE MECHANICAL GOVERNOR. WHAT PARTS ARE NEEDED BESIDES 691997 SLINGER & 692232 SUMP GASKET? THANKS
Problem solved by replacing to two mentioned parts. I was told that sometimes it is also necessary to replace the camshaft as some of the plastic teeth on it could also be damaged.
Oct 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
218 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
