Question about Furniture
The foot rest is out about 4 inches and sitting on the floor.cannot get it back
BVoise ,Idaho area I need a service man 1208-482-9908
2 Suggested Answers
jonsnell4
  • 25735 Answers
SOURCE: My hallway is 11 foot 10 inches by 2 foot 4 inches how many metres of Lino floor covering do I need to cover it
A metre is 39" x 39". It is easy to work out from there.
Posted on Aug 23, 2017
Does a quarter inch quilting foot come with the machine, if so what does it look like?
If your machine is considered a "quilting" machine, it may have a 1/4" foot included. However, most machines do not include the 1/4" foot. A quarter inch foot looks a lot like a basic presser foot except the edge should be 1/4" away from the needle.
FWIW, you can achieve a 1/4" seam by placing a ruler under the presser foot and gently manually lowering the needle point until it rests on the ruler's 1/4" mark. The ruler's edge would then be exactly 1/4" away from the needle. You can place a piece of painter's tape (on the sewing surface) adjacent to the ruler edge and this would serve as your quarter inch guide.
Even if you decide to purchase a quarter inch foot, in my experience, none of them provide the "scant quarter inch" seam for piecing. Other than marking a scant quarter inch measurement on your sewing machine, achieving it will usually take some testing to determine what constitutes a scant quarter inch on your machine.
3 Ways to Master the Perfect Quarter Inch Seam
http://quiltville.com/quarterinch.shtml
Scant 1 4 seam allowance
Accurate Piecing Basics Quarter inch Seams WeAllSew
Jan 18, 2018 | Sewing Machines
I have a vintage Murray Riding Mower, model number is missing has three blades each blade is 15.5 inches Need belt diagram to install both belts to deck
If you have info numbers off the engine, usually found stamped on the top front area, it should at least give you an approx. year.
Sometimes there is a belt diagram under the foot rest area.
Worst case : The belts always fit/sit with the flat part to the flat pulleys and the v part of the belt to the v pulleys.
Oct 24, 2015 | Murray Garden
HOW DO I CALCULATE THE SQUARE FOOTAGE NEEDED TO LAY A WOODEN FLOOR?
Hello, width x length,measure the largest portion of the room and if you have a small area like a alcove measure that also then add your totals up. hope this helps
PS I try to convert to feet
Mar 20, 2015 | TA Laminate Sierra Maple Flooring
How much area is a square foot?
A square foot is by definition 12"x12" or 144 square inches. Measure your area in inches, multiply the length by the width and divide the total by 144 to figure the square feet.
Feb 24, 2015 | Building Materials
What is the average weight for 5 foot 7 inches?
Female Ideal Weight - Above Average Height The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds. Male Ideal Weight -- Under 6 Feet Tall Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
Jul 09, 2014 | Health & Beauty
In which country has a area code of 324
There is no 324 area code in the United States, but many people nationally have reported receiving scam calls that showed up on their caller ID systems as originating from the 324 area code. One Internet source, wikianswers.com, reports the calls appear to be originating from Ghana, West Africa. A Northern Oklahoma businessman said he recently encountered an apparent credit card scam that used the 324 area code. A man who identified himself as Preacher Tim from Idaho tried to get the businessmanto send 600 blankets to an orphaage in Idaho, he said. The scams reportedly take many forms, but a call that appears to originate from a 324 area code should be cause for suspicion, unless a person is expecting a call from Ghana.
Apr 28, 2011 | Computers & Internet
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
Dec 04, 2010 | CRL Fixed "All Glass Look" Window for Side...
I need to find the kick panel on a 95 honda EX 4 cyl engine?
on the drivers side sit in the seat and with your left foot kick to the left that wall / area under the dash from the door, to the floor, to the firewall is referred to as the kick panel. revers using the right foot for the passengers side.
Sep 11, 2010 | 1995 Honda Accord
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Furniture Logo
560 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
