Question about Hard Computers & Internet
Unlock this drive using your recovery key
Am facing problem with hard disk 1TB , External , when i connect to any system asking unlock this drive using your recovery key i have any key or password , any solution to reset it with data backUp?
  • 720 Answers
Sounds like you have been hit with crypto locker virus.
Posted on May 08, 2016
  • 3 Answers
SOURCE: Computer does not recognise Hard Drive
Hey guys. I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
Posted on Jul 01, 2008
  • 29 Answers
SOURCE: Hitachi HDD unlock
as far as i knew,the HD Doctor from salvationdata can help you with the password,their website is:http://www.salvationdata.com
Posted on Apr 14, 2009
  • 497 Answers
SOURCE: Wiping WD hard drive
I suggest that you use Darik's Boot and Nuke ("DBAN")application to completely Esare the Hard Drive. It is a freeware application.
Darik's Boot and Nuke ("DBAN") is a self-contained boot disk that securely wipes the hard disks of most computers. DBAN will automatically and completely delete the contents of any hard disk that it can detect, which makes it an appropriate utility for bulk or emergency data destruction.
For detail visit:
http://www.dban.org/
Good Luck!!!!!!!!!!!!!!!!
Posted on Sep 08, 2009
Crankstart
  • 696 Answers
SOURCE: I have a Lacie 250 GB hard drive. My computer can't find/access.
Thanks for all the info, it really helps us help you when we have the full picture.
The Seagate drive you are seeing is the hard drive inside the Lacie Enclosure. The fact it is showing up in disk management is a good sign for getting your files back. The fact that it shows as empty with no format type listed means that either the partition was deleted or damaged. This would be akin to loosing the microfishe in your local library. All the data is likely still on the drive but windows has no way of knowing what is there or where it is.
In either case the data can generally be recovered by a pro with speciallized software. In some cases you can do this yourself with similiar, less expensive software but I always warn Askers that this software requires significant knowledge to operate and you cannot recover the files back to the same drive therefor you must have another drive with at least double the space free of the data on the drive to do it yourself.
Let me know which approach would suit you better, if you choose the do it yourself method I can suggest software for <$100 that you can try but it carries inherent risk of damaging the data if you make any mistakes. f you choose to have a pro do this for you reply with your Country, State and City and I will recommend someone for you. For this type of failure recovery varries but usually runs $150-$500 depending on the volume of data you have.
In either case DO NOT format the drive or attempt to use it for anything in the mean time as every operation that writes to the drive runs the risk of overwriting your data and rendering it unretrievable.
Hope this Helps FixYa,
Chris
Posted on Sep 13, 2009
  • 14 Answers
SOURCE: Maxtor Basics external portable hard drive not getting detected
Well, data recovery service is pretty expensive. In your case the MOST effective way is to try some so-called data recovery software. See if you can grab some of your precious data back.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem! Remember - Always make multi-Backups of your precious data!
Posted on Jan 13, 2011
1TB MP Hardrive now unreadable, how to i backup my files
there is a possibility that your hard drive got logically damaged. but you need not to worry you will get back your all the files by using a hard disk data recovery software that will get online in both free and paid version. If still you will face any problem drop me a reply.
Feb 21, 2013 | Western Digital My Passport Essential SE...
I forgot my password for my buffalo hd-pntu3 what will i do i don't want to delete my data
Download the
HDD Unlock Wizard HDD Unlock Wizard v4.2 http://www.filebuzz.com/publisher/download.php?id=98078
HDD Unlock Wizard is a window based utility.
It works as a new life for your locked hard disks, as it is competent to unlock almost all hard disks of major brands available in market.
Its proprietary unlocking algorithms can remove any unknown HDD password and you do not required to give any hint of password as it is not working as a normal password cracker tool.
Removal of a HDD password is a slow process and total time required to remove HDD password is depending on the size of the hard disk and type of hard disk.
A small 2.5" notebook hard disk takes more time as compared to normal Desktop hard disk.
Presently it supports IDE and SATA hard disks.
hope this helps
also you might try
http://download.cnet.com/siw-portable/3000-2094_4-75449686.html
Software Inventory: Operating System, Installed Software and Hotfixes, Processes, Services, Users, Open Files, System Uptime, Installed Codecs, Software Licenses (Product Keys / Serial Numbers / CD Key), Passwords Recovery.
Oct 12, 2012 | Buffalo Jeans Buffalo Technology...
HELLO! MY PROBLEM WITH MY HARD DRIVE IS THAT I DON`T SEE ANY WAY TO UNLOCK IT. WHEN I CLICK ON IT,SAYS "ERROR RECOVERING DISK F: A RECOVERY KEY WAS NOT FOUND ON THIS DRIVE. THE DRIVE CANNOT BE...
Hello, have you somehow locked the drive or what have you done to reach this point? this does not sound normal, also if you could post the brand and model.
Feb 14, 2011 | Western Digital My Book Essential 1TB...
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
When i connect two external hard disks (each 1TB), i can't see the data of one of them
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 14, 2010 | Western Digital My Book Essential 1TB...
My wd my book essential 1tb hard drive when conneted to power beeps for 20 secnds or so then the lighs just flash it will not show up on my mac or pc is there anyway to fix it?/
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 22, 2010 | Western Digital My Book Essential 1TB...
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Oct 20, 2009 | Western Digital Computers & Internet
My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Hope this helps FixYa,
Chris
Jul 16, 2009 | Buffalo Technology 1TB DriveStation...
Computers & Internet Logo
132 people viewed this question
Top Hard Computers & Internet Experts
David Clark
David Clark
john smith
Nyte_Ryder
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
