Question about GPX Audio Players & Recorders
My cd/dvd player on my gpx boombox will not open or close nor play at all, how can I fix it?
  • 30 Answers
SOURCE: Sony CFD-S300 boombox would not run CDs
what i would suggest you to do is get a q-tip and a little bit of rubbing alcohol on the tip and gently clean the lens let it dry
Posted on Jul 17, 2007
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
fairlane
  • 50 Answers
SOURCE: Boombox CD player
Hi Could be bad spin motor, but the first thing to try is load the cd and put your ear to the unit and listen for a ticking sound...if there is, then the laser is trying to focus. If not ticking, there is likely a serious problem, and the whole unit should be replaced. If you hear the lense bouncing up and down, then it is likely a dirty lense or bad laser. To clean it, use a cotton swab and wet the end with at least 70% USP rubbing alchohol(99% better). Touch the swab to the lense and a drop should form on the lense, gently move the drop around to loosen any debris, and then use a dry swab and touch it to the lense to absorb the drop. Try the unit, and if it was dirt on the lense, it should work, if not the boombox should probably be replaced. Good Luck!
Posted on Sep 27, 2007
Kaoeria
  • 36 Answers
SOURCE: CD player/boombox
Alot of cd players, theres a tiny tiny pin hole you can fit maybe a sewing needle, or the end of a paper clip into... do it, and ull probably feel a lil resistance while the internal button is pushed...once u hear like u pressed it, the tray should open.
Posted on Dec 28, 2007
SOURCE: Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Posted on Feb 24, 2008
My 32-inch GPX my 32-inch GPX HDTV with built-in DVD player DVD player will not open or closed or load with the DVD in it
there is a pin hole on the dvd/cd player simply put a pin into it and ur cd/dvd door will open.
Dec 24, 2017 | GPX Televison & Video
Can't play the cd
After putting in the CD, move the switch on the back to the CD/Line In position. (The other switch positions are Off, AM, FM.) The switch is next to the Line In (3.5 mm) jack. Then press Play/Pause on the front of the boombox. This is the single button on the left side (The adjacent pair of buttons are the search (reverse/forward tracks). On the other side of the LCD display are the Stop, Repeat and Program buttons.
GPX has the manual for the GPX BC232 on the product page: http://www.gpx.com/store/p/822-BC232R.aspx . Click on the tab for Downloads to get the manual link. The direct link is http://www.gpx.com/owners_manuals/BC232-578-01-IB.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Jan 08, 2013 | GPX BC232R Radio CD Player Boombox
LID WON'T CLOSE ON CD PLAYER
The CD loading mechanism have the fault. Check its loading belt. If loading belt has broken, the try wont close of open. If loading belt is OK. replace the loading motor.
Aug 12, 2012 | GPX Audio Players & Recorders
TROUBLESHOOTING
some of those will not play burned cds it can detect if it is
May 07, 2012 | GPX C983 Cassette/CD Boombox
I need a 2 pin ac cord for my gpx Q916 boombox cd player.
the cord you need is fairly common, you can find them at walmart or radio shack
Jan 12, 2011 | GPX C969 CD Boombox
Code for multi region free
I figured out the code, it's printed incorrectly many places.
1 - Turn on DVD Player
2 - Press Open/Close button - open tray
3 - Press "8888"
4 - Put a DVD in the tray (from outside your region)
5 - Press Open/Close button - close tray
6 - Voila! It plays!
Works on mine!
Apr 01, 2008 | GPX D1816 DVD Player
CD Player display always show "Open"
Theres a protruding plastic that pushes the close detection switch inside, the switch might have gotten dirty or reshaped, you can remedy this by adding height to the protruding plastic, or have someone disassemble the unit for you. It can easily be remedied by a technician...
Dec 02, 2007 | Coby MP-CD450 Radio/Cassette/CD Boombox
CD Player Issue
the system has problems reading burned CD's u cant fix it or anything windman
Jan 30, 2006 | RCA RP-9316 Boombox
224 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
