Washer stopped working registers 1E - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 30, 2015
My Samsung Washer has a code of 1E which means maybe the water level. My problem is that it want turn off. Even when I push the stop button. The door is locked and it keeps beeping and flashing
1e is usually a pressure sensor error. To open the door you will need to switch off the appliance at the wall then after about 2 minutes the door should unlock. You could try the appliance again as it may just be a glitch but you will probably need the pressure sensor.
Good luck.
Dec 17, 2015 | Samsung Washing Machines
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
LG Tromm wm1815cs front loader washer error message 1e. Have cleaned filters, checked hoses,and supply source, I still get message,
R u sure it is not an (LE) error code. Kinda looks like an upside down (F)? Very common on older LG washers. Indicates a hall sensor/ motor position sensor error.
Mar 22, 2015 | LG Washing Machines
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
My Fujitsu Cash Register has stopped working
1E indicates a problem with the internal memory.. Sadly there isnt much you can do on your own it will need to be taken to a local dealer for repairs.. Yo can try unplugging it for a few minutes but thats about all you can do,, The internal circuit board needs to be replaced.
Dec 28, 2012 | Computers & Internet
I have a maytag heavy duty stack washer dryer. tonight The washer stopped working. The elctronic panel seems to be working and the water filled but the machine would not aggitate, spin etc.. it did show a...
Possibly the timer needs to be replaced, if a few of the teeth on the disc get broken off, it will not turn, and that causes it to NOT go into the next cycle. Happened to me, thank God for warranties
Jul 31, 2009 | Maytag Bravos MTW6600T Top Load Washer
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Lg washer wm2277
The "1e" is actually a LE or Load Error. Search for it on this site and you will find many responses covering it. Some can be somewhat serious, but the most common cause is drag on the drum due to too much and / incorrect soap. Always use HE (high efficiency detergent) and no more than one tablespoon per load.
Sep 13, 2008 | LG WD-1280FHD Front Load Washer
MAGTAG STACK WASHER
The 1E error codes relates to a lid lock failure. You should replace the lid lock switch. Good luck!
Nov 21, 2006 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
