Question about Air Tools & Compressors
My air comp:is not building air. 1- head intaking air, and the other Head is blowing out.what is my promblem?
    President:
  • 1,388 Answers
If the heads were taken apart most likely the valve plate was place backwards causing air to come out of the intake. If the valve plate is on correctly, air coming out of intake is caused by faulty gaskets or leaking reed valves. Good luck
Posted on Jun 12, 2015
  • 1388 Answers
SOURCE: Compressor is building up pressure very slow.
It could very well be the valve plate however before you order parts take a look at the cylinders. Unplug the unit, remove the cover from crank side and turn the compressor by hand till the/a piston is at top of stroke. Examine upper cylinder for scratches /wear or failed vinyl piston ring. On oil-free compressors, dirt and grit is sucked-in from the bottom of the cylinder and causes leaks between cylinder wall and piston. If scratched, air pressure is leaking down thru cylinder wall. Failed reed valves cause a pulsation at the intake port (air seems to be pumped out the intake). If you see a model number anywhere on the pump that begins with " WL", your pump is made by Campbell Hausfeld. Parts can be ordered from www.chpower.com. other-wise order parts from sears parts. Cylinder kits are around $40. Good Luck on the repair and email if you have questions.
Posted on Apr 02, 2009
  • 3600 Answers
SOURCE: ingersol rand model SS3-E runs but does not build
the back pressure valve has failed it costs about 15.00 and can buy from any truck parts store That's Peterbilt trucks or any large truck stores it's one of two sizes 1/2 inch or 3/4 inch when you pull it off be sure you know which way the air flow is or it will not build up.
Posted on Nov 26, 2009
digritz
  • 530 Answers
SOURCE: Air leak on top of cylinder head
In all likely hood a flapping noise coming from the cylinder head means an issue with either the intake/exhaust valves or one of the restrictor plates. If you click the link below you can find a diagram for the cylinder head, page B part #107 and #110. You can also get replacement parts from them if needed.
I really hope this helps.
http://www.ereplacementparts.com/porter-cable-cpl6025-gallon-oil-lube-compressor-parts-c-129_1662_2214.html
Posted on Dec 26, 2009
roniecon
  • 6927 Answers
SOURCE: clarke air comp. parts
www.aavolyn.com/it070002.htm. try this on line
Posted on Jun 23, 2010
heatman101
  • 43501 Answers
SOURCE: my kobalt air compressor starts and builds
It could be a valve/head problem, but it could also be a cylinder/ring problem...to find out it will need to be disassembled...that is not hard... getting parts to reassemble can be the hard part...
heatman101
Posted on Sep 08, 2011
Why wont my steelcraft 13 gallon 5hp model ta25 build up no more then 20 pound of pressure and all i did was change the oil?
Check all connections for air leak including the water drain valve with soapy water. If no air leaking from connections, spray soapy water on head area where head attaches to the cylinder checking for gasket leaks. If no leaks are found, most likely problem is in the head /valves /internal gasket leak. If head gasket or valves are leaking, you will notice that air seems to blow out of the intake filter (normally there is good suction at the intake). Good luck
May 16, 2014 | Air Tools & Compressors
Why is my mid 70's 2cylinder Worthington shop air compressor ( for powering pneumatic tools) suddenly leaking the compressed air out of the tank, back up through the air filter ?
You will probably have reed valves inside the head. One may be bent or broken or you may have simply blow a head gasket which is easy to fix. just google reed valves in a air compressor and you will see the setup.
You will need to take the head off which will be 6 or 8 bolts and have a look.Not hard If it is a gasket it will only cost you $30 or $40 for a kit.
May 11, 2014 | Air Tools & Compressors
How to remove muffler intake from Porter Cable CPF6020-1 air compressor
To remove the air filter intake muffle you will need to remove the 4 screws that hold the head on to the pump.
There is a O-ring under the head you will want to put a little vasoline on before you reassemble the head back to the pump.
The new muffler kit should be the KK-4981
Sep 10, 2012 | Porter Cable Air Tools & Compressors
Alton 1/3 hp 2 gallon air compressor, building no pressure and sounds funny
Is your compressor a piston compressor? It may be that the valves in the head are shot?
Remove the Air Filter and quickly place your hand over the air intake hole, if you feel it **** AND blow, then theres your problem (It should only ****) these can be replaced.
Aug 18, 2012 | Air Tools & Compressors
MY COOLANT LIGHT CAME ON IN MY 2001 SILHOUTTE
more than likely intake and head gaskets are bad,looking at approx $900.00-1000.00 head gskts if heads are o.k. and about $600.00 for intake gskts. common problem on 3.4
Jan 04, 2012 | Cars & Trucks
Hitachi Ec 119 compressor will not build pressure beyond 25 pounds; no air is heard leaking after I power down the machine. Is it likely the check valve or pressure switch?
If your compressor keeps running and only builds to 25psi, I would suspect the reed valves, head gaskets or a leak. With the compressor running spray soapy water on all fittings, around the head area and tank components. If no leak is found, remove the air filter and feel for suction at the intake(make sure head is not too hot). If you feel good suction at first then suction is lost after reaching 25 psi, most likely reeds or gaskets (with bad reed valves, sometimes you will actually feel air blowing out of the intake). Good luck
Oct 15, 2011 | Hitachi EC119SA Twin-Stack Air Compressor...
I have a Craftsman 3.5 hp, 25 gallon compressor. The compressor runs fine, but will not build pressure. Tank has pressure from the last cycle so I know it is not leaking. The compressor runs but no...
Hi Jim,
Disconnect your main air supply from the comp head to the receiver/tank and see if their is a reasonable air supply to atmosphere.
If not check that air is being taken in by the head intake filter
John
Aug 05, 2011 | Craftsman Air Tools & Compressors
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Coolant comming out of tail pipes when engine is running? No leaks in engine compartment Chevy 350, high comp, Camle hump/mickey mouse heads. Engine mounted in 1967 Firebird Engine is made before 86, but...
New head gasket gasket needed would be my first guesses. Sounds like vacuum from the intake stroke is sucking coolant around the gasket from the block on the intake stroke. How does the oil look?
Sep 21, 2009 | 1983 Chevrolet Camaro
Air Tools & Compressors Logo
158 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
