Question about HP iPAQ H5450 Pocket PC
How can you help me to get on line with my IPAQ?
Wireless networks says connected, but I still can surf the internet.
    Habit-Forming:
  • 46 Answers
Fairly comprehensive answer to write out so here is a link, and navigate to the connectivity section
http://www.hp.com/ctg/Manual/lpia8010.pdf
Posted on Apr 28, 2015
Why can't my dell inspiron 530s desktop install
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers. Hope this helps
Dec 19, 2012 | Computers & Internet
I have hp pocket pc,but problem is that i can not connect with internet.plssss replay me how to connect with internet
What model is your ipaq? Does it has WIFI? If it does then:
Make sure that your WLAN is ON
Go to:
Start, IPAQ Wireless, and turn ON WLAN then:
Go to:
1) Start,Settings, connections tab, connections again, Advance tab, Network Card and you should see your Wireless networks.
From there it will vary depending if your wireless device has security on. WEP, etc.
Hope this helps.
Aug 16, 2010 | Microsoft Windows Mobile 2003 for Pocket...
On a new iPAQ 111, I can't connect to a network wirelessly
Have you tried resetting your iPAQ? You do that by pushing the little button on the side with the stylus. The screen will go blank for a bit, and then windows will restart. I had bought mine used, and when I got it, I had the same problem in that I never got the screen that let me select the wireless network. It fixed mine. Once it is working again, try selecting "View WLAN Networks" again, and you will see a list of networks that it can hear. If the SSID Brodcast is enabled on your wireless access point, you will see your network there. If SSID is not enabled on your WAP, you will need to type in the name of your network before it will find it.
Hope this helps. Sorry it was so late in being posted.
Jun 30, 2010 | HP iPAQ 111 Classic Pocket PC
IPAQ RX3715 can't log on to home network
Try upgrading the firmware on the router and then connect the IPAQ and computer to the wireless network
Jun 11, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Compaq ipaq
hi i am wolson so i have a problem with my pocket pc so i need connect it to the internet but i can't can you explain what i suppose to do please
Apr 03, 2008 | Compaq iPAQ H3765 Pocket PC
HP IPAQ 2003 internet problem
This problem seems to be with the wireless network itself. Perhaps it's not connected to the Internet even though you are connected to the lan. Make sure your default gateway setting is the same as that of the lan. If there is lan administrator, obatin the settings you should have from that person.
Jul 21, 2007 | HP iPAQ H4155 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
Wireless Internet on iPAQ 2215
You will be wanting an SDIO wireless 802.11b card.
Sep 15, 2005 | HP FA162A for iPAQ 2215/4155 Keyboard
HP iPAQ hx4700 Pocket PC
if your PCs connect wireleslly, then I assume you have set up a home network with a router/modem. Sometimes the modem comes combined with a router. If this is the case, then the 4700 has all you need to connect it to this network and access your emails and internet. This is an example of my setup with my 4700... Go to Start > Settings > Connections > Connections > click on Advanced tab at the bottom click on "Select Networks" button Both entries on this page should be set to "My Work Network". Click "OK" > "OK" back to Settings screen. Go back to Today Screen. Now click on the iPaq Wireless icon at bottom right of this screen. If the WiFi button has an 'x' on it then click it to turn it on. A blue light should now come on at the top of your ipaq to indicate that wifi is on. Click on the 'Settings' button You should be able to see your network on this screen - "Configure Wireless Networks" Networks to access should be set to "All Available" Check the box to 'Automatically connect to non-preferred networks' If the Network is available but not connected, then click on it's name. On this next screen you should select next to 'Connects to' - "The Internet" Then click OK If the Network shows 'Available' and not 'Connected' then click and hold on the name of the network and then you can choose 'Connect' Then under 'Network Adapters', on that screen it should say ... My Network card connects to 'Work"
Sep 07, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ H5450 Pocket PC Logo
176 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
