Question about John Deere Garden
Have lt155 john Deere mower. When cutting blades are engaged, pushing reverse pedal all the way down cuts out motor. Yellow lockout button is also pushed in.
  • 41 Answers
A lot of mowers have a safety feature built into them that don't don't allow reverse mowing, there is a sensor switch that cuts the motors when depressed. you can however override this safety feature by removing one of the wires off the reverse pedal depress switch, but do so only if you are a competent confident user of the machine. And remember to reconnect the wire if there will be other users.
Posted on Apr 28, 2015
  • 54 Answers
SOURCE: Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Posted on Apr 28, 2010
  • 391 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
  • 66 Answers
SOURCE: mower cuts out
I would check the seat switch first. I had one that did that that ended up being a bad cell in the battery and a faulty charging system. Does it have an amp gauge on it to see if its charging ok?
One other thing....you say that it tries to stay running when you slightly depress the brake...is that including the pto? www.nnyparts.com
Posted on May 30, 2010
  • 6468 Answers
SOURCE: mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
Posted on May 17, 2012
stapes613
  • 6 Answers
SOURCE: john deere mower stopped cutting
it could be a few different things it depends on if it is a electric clutch or manual for engaging the deck. It also could be a bad pulley on the deck
Posted on Jul 28, 2012
My 318 John Deere mower blades would not turnoff. The switch would not move. Even when I got off the seat the mower blades continued. I turned the motor off and now it won't start. Any idea?
Faulty attachmentment switch, replace it as it is sending a signal that it is engaged to your starter circuit, that is why it wont start.
It is also faulty as it wont engage the attachment (mower cutting deck)
Aug 03, 2015 | John Deere Garden
My Lt155 ride on wont engage in forward or reverse
(Simple answer)Hydrostatic drive machines have a setting that allows you to push them. machine won`t move if this is engaged.
Also If park brake is on. Otherwise check drive belt has not snapped is loose or broken. Jack machine up and see if wheels will drive without weight of machine.
Jul 26, 2014 | John Deere Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
I just bought an old John Deere 68 riding mower but it does not cut grass even though the blade spins when engaged. I made sure the blade was on correctly but it still doesn't cut. I noticed the pulley...
Are you sure it is the correct blade and when it is turning the sharp edge is on the leading side? A spinning blade will cut grass even if the blade is dull. Did you lower the deck to the correct level?
Jun 28, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Hello Sir, I have a john deere 25 horse 48 inch cut,the first thing that happen was the orange button you push to back up with blades engaged quit working and then the blades wouldnt come back on after...
sounds like the switch is bad, you will need to check it, as it may be just a loose connection, you can jump it out to test it out, or just straight wire it. Good luck Tim
May 22, 2011 | John Deere Garden
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Sep 29, 2009 | Garden
John Deer X475 lawn mower
Check fuses.Does the dash light for PTO come on?Right side screen by pedals sometimes comes in contact with wires and cuts them.This happens mainly on the older units.
Sep 19, 2009 | Garden
Garden Logo
150 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
