Question about Fiat 500 core. heater. . a/c and heater unit core. heater
The heater is set at 32 degrees but only blows cold air the water bottle is at the right level and the fan runs
  • 41 Answers
Sounds as if your Thermostat is faulty and remaining in the closed position, pop it out, boil a kettle of water drop it into the hot water and check if it is opening.
If it does open then your problem most likely is a dirty heating system and it needs to be flushed.
Posted on Apr 28, 2015
Why is my heat or air is not blowing and car is running hot
How hot is the engine running in degrees f? Does the radiator fan run?
With hvac turned on, check voltage and ground at the blower motor. If good voltage and ground, suspect the blower motor is faulty.
Jan 02, 2016 | 1992 Saturn SL
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
How do you open the moist cap? i want yo fill it with water but it wont open
What is this cap on?? Radiator or windshield washer reservoir? Something else?
If the radiator, most newer cars have a plastic bottle or tank that has a "cold" and "hot" level indicated. You should be able to see the coolant level thru the tank. You should NOT need to open the radiator cap if your car has this tank. Add a 50/50 mixture of water and coolant (of a type your car requires) up to the "cold" mark and start the car. Let it run with the heater set to HOT and fan set to HIGH. Continue adding the 50/50 mixture to maintain the coolant level to the HOT level mark on the tank as needed with the engine running. Stop when there is HOT air blowing out of the heater.
If your car does NOT have this tank, you may only open the radiator directly when the engine is COLD. Wait several hours for the engine to cool after shutting off before attempting to remove the cap.
When cold, press DOWN on the cap WHILE turning. Most caps will come off after a 1/4 to a 1/2 turn. Start the engine and set heater HOT and fan to HIGH. Continue to add a 50/50 mixture of coolant to the radiator until the heater blows HOT air. The coolant level in the radiator should be just under (1" or less) from the bottom of the radiator opening.
Was this the info you're looking for?
Sep 13, 2013 | Cars & Trucks
Heater blowing only warm air, fan is fine. no leaks on heater core where is the control for the heater located
Make sure you have the coolant level at the correct level in the bottle resorvoir. If there is not fluid to circulate in the system, the fan will only blow a cool or lukewarm temperature air. If there is enough coolant, check that the water pump is working.
Jan 16, 2011 | 1995 Dodge Dakota
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to replace thermostat on
Do this when cool. Take radiator cap off, start the engine, turn on heat (not defrost) and now top up coolant to about an inch or 2 from top of radiator, as level drops down, and let vehicle run until the radiator fan comes on, then off, about 3 times, and add coolant as needed while it's running. After that, put radiator cap back on tight & make sure return bottle is filled to proper level. Now try that & see how heat is, temperature gauge etc, and keep an eye on return bottle level for a while. Let me know how it is.
Mar 27, 2009 | 1992 Nissan Maxima
Heater blows cold air from top vents after running for 1.3 hours
Sounds like you may be able to fix it by flushing your antifreeze and back flushing the heater core. Some car owners cheep out and put stop leak into the antifreeze, others dont change there antifreeze at all. Both are mistakes.
Mar 05, 2009 | 1990 Chevrolet Lumina
Engine overheats when heater pipes connected
I think you could be right about there being air trapped in the system.
Or the heater core(radiator) is plugged.
Either way you need a pressurized radiator coolant pump to put the coolant in without air being trapped.
Although,i have seen it done by jacking the vehicle up high enough that the radiator was now higher than the heater core level, and then the coolant was put in.
But this is dangerous to try.
Jan 29, 2009 | 1999 Ford Escort
1994 nissan pickup--heater not blowing hot enough air
your fan motor is shot, motor has bad brushes replace it, if u feel its still not hot, drain your rad and but a 28 oz bottle of pine sole and add water till full, run it for about 20 mins. drain, run strait water, drain, then put anti frezz in with water, 50/50 mix or mix your own. it should clean your cooling system compleatly out.. do not turn heat on while pine sole is running throw it, gives of a bad smell.
bert
Jan 28, 2009 | 1994 Nissan Pickup
First thing you need to do is pull rad cap off & see where your coolant level is at. If it's low, top it up, start engine with heater (not defrost) on & let it run for a while with cap off & top up as needed, to see if it starts to get heat. After rad fan comes on a couple of times & operating temperature is good, put cap back on & fill return bottle to proper level. Keep an eye on that bottle level for a while, in case your losing coolant somewhere. If that doesn't cure your heat problem, change thermostat & refill coolant in same manner as mentioned above.
Jan 17, 2009 | 2000 Oldsmobile Intrigue
Fiat 500 core. heater. . a/c and heater unit core. heater Logo
88 people viewed this question
Top Fiat Home Experts
Donni Steen
Tom Chichester
Are you a Fiat Home Expert? Answer questions, earn points and help others
