My Television cuts the edges off the screen when connected to pc through HDMI.
Therefore, I need the tv to accept the HDMI connection as a pc source, and I can't find any way to do so.. anyone got a clue what to do?
  • 1153 Answers
SOURCE: No High-Def via monolink(HDMI) connection
Troubleshoot first by self diagnosis
Posted on Dec 16, 2007
srinivasb81
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Posted on Mar 30, 2009
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
valiantma595
  • 176 Answers
SOURCE: connecting Bravia to PC using HDMI cable
You did okay but the phono sockets are not for Computer/TV use. Phono sockets should be checked int the manual on why they're there. If you have connected the Bravia to your computer, using the appropriate cable, then you should also purchase or request from the retailer where you purchased the TV a cable that has stereo phono plugs and, you didn't say what size phono sockets they are but I presume they are 3.5 mm. So, if the TV has 3.5 mm sockets, you purchase a cable with stereo 3.5 mm plugs. This is adequate for the stereo wav sound coming from the computer and going into the TV. Remember, having 2 Phono inputs on the TV doesn't mean anything. The TV could have a number of video inputs too, ATD AVT, AV, COMPONENT1, COMPONENT2, HDMI1, HDMI2, HDMI3, etc. each have it's respective sound inputs for AV, S-VIDEO, DVD, Blue-Ray, etc. But for the computer there may be a different type of socket for it's sound inputs, normally it is the old phono sockets. Seek help from the retailer or else you could cook the circuitry of the TV's sound system.
Posted on Sep 18, 2009
Acer Aspire 5630 hook up to television
Your Acer laptop has a 15-pin VGA port on the rear. It may also have a S-Video and/or a DVI-D port. Any of these can be used to connect to a television monitor. None of these connections, however, supports the sound portion of the signal. You will therefore require two cables, one for the video, and one for the sound. The sound will be a regular 1/8" stereo jack on the PC side. You will need to look at the TV to see what types of connections it accepts. There may be HDMI, DVI-D, S-Video, or RCA connections. Select a cable which matches the connections for each end for both the audio and video.
Dec 11, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
DVI to HDMI
HDMI and DVI use the same encoding scheme for video purposes- the only difference is HDMI can carry audio signals and therefore have different connectors- so it is not like the lack of a picture signal is because you are using two different cables (HDMI and DVI). In theory the DVI to HDMI adapter should work.
Is there a possibility that the adapter is defective? Any bent or missing pins?
How long are the cables? If they are of poor quality, a digital signal can be lost at 20 feet. Again, in theory.
The only other thing I can thing of, off the top of my head is to ask, did you change the input selection on your t.v.'s display screen to go from the input source that you get your t.v stations from... to the input source of the Play Station?
Nov 27, 2013 | Toshiba 50HDX82 50" Rear Projection...
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Can not hook up to my Toshiba TV what cord do i need in order to make it work
Since this model of All-In-One Computer already has a built-in Digital/Analogue Television Function, as part of its standard specification, I will assume that your reason for wanting to interconnect these two devices is that you want to export computer, internet or other IT-based multimedia images to the TV for an enhanced viewing experience due to the TV's larger screen size.
The All-in-one computer has a High Definition Multimedia Interface (HDMI) Port.
If the TV also has an HDMI port, what would be required is the best quality HDMI Cable that the User can afford.
All electrical/electronic interconnections between cables and ports suffer some degree of degradation or dissipation of the signal traveling along the cable. The most efficient metal for electronic connections is gold due to its comparatively high level of electrical conductivity compared to that of other metals used for electronic interconnections.
The best cable choice would therefore be a gold-plated HDMI Cable (see below).
If the TV has no HDMI port, an HDMI to Video Graphics Array VGA Cable Adapter or ([Victor] Radio Corporation of America - the inventors) RCA/PhonoVideo Cable Adapter between the HDMI Cable leading from the computer and the corresponding VGA or RCA/PhonoVideo port on the TV should resolve the connectivity mismatch (see images below).
Once connected, the TV Remote Control should be used to change the Signal Source Input from its automatic standard (Default) setting to PC Input:
Menu -> Source -> PC -> OK.
Nov 25, 2011 | Acer AZ5700-U4002 23-Inch All-In-One...
How do I connect acer aspire to tv
You will need an HDMI cable. Connect the laptop to the television and on the television, you will need to change the "Source Input" setting. Select the HDMI setting on the television and everything that you see on your laptop will appear on the television.
Oct 23, 2011 | Acer Aspire One PC Notebook
I am able to stream netflix, however, I was told I should be able to access everything else from my PC on the TV, as well. Therefore use my TV as a laptop. How do I do that??
If your Television has netflix installed on it, you will need to connect the television to the internet and follow the on screen instructions to enter your information.
If it doesn't, you will need a device that has netflix on it that can connect to the computer (an xbox, PS3, Wii, or compatible player) that can connect to the internet. Again, connect the device, choose netflix, and follow the onscreen instructions.
I can provide more details about these on screen instructions if I know what device you are using.
As a third option, you can connect your laptop to the TV with any video or audio cord. HDMI is a favorite if your computer has an HDMI output port and your TV has an HDMI input.
Jul 21, 2011 | Computers & Internet
Iplugge in my PS3 using an HDMI cable and i get no feedback
ps3's are a pain in the _ss..
you need to connect it through your standard cables as well.. use the component cables that came with the ps3 and connect it to your tv's coloured inputs..
change the tv to that source and then go to the video settings on the ps3, and then choose the hdmi option..
now.. once the option is chosen, you have about 30 secs to change the source on your tv to the hdmi source to see the picture while the timer counts down (making sure both the hdmi and the component cables are connected to the tv at the same time)..
now that you are on your hdmi source on the tv, choose accept (X) on the ps3 menu and you should have your hdmi setup
if you run out of time, no problem, just go back to your component source input and repeat the process faster
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
How to hook up your computer to your tv
You will need a TV tuner or Video card with a built in TV tuner.
Nov 20, 2009 | HP Pavilion m7580n PC Desktop
Connection to a computer
This TV has an HDMI interface, not DVI. If your source is DVI, you can get an DVI to HDMI adapter. The HDMI carries both video and audio data, so you will need to connect your audio separately.
May 10, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
