Question about Viking Professional VCBB363SS Stainless Steel Refrigerator
How do i fully turn off fridge
Need to turn off completely.
  • 4,348 Answers
Unplug it.
Posted on Apr 28, 2015
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
What will happen if I bottle my beer before its fully fermented? Is it dangerous?
It's really important that fermentation is complete before you start the bottling process for the following reasons:
If beer is put in the fridge before fermentation is complete, it will continue to ferment albeit at a very slow rate.
If you then take it out the fridge, active fermentation will re-start.
This could lead to bad beer, burst bottles and even injury, so be really sure that fermentation is finished before you start your bottling.
Feb 21, 2013 | Crafts & Hobbies
Fridge doors do not close completely
1st ckeck that nothing is sticking out just far enough to pop the door open.if not that, than the gaskets can were out on frig doors , you can order it on line from all appliances, get the model # from inside the frig , be patient installing it , its tricky, but it can be done by Harry homeowner. good luck.
May 04, 2012 | Maytag MSD2756GES Side by Side...
My L.G french door frige GR-B218WV ices up under the freezer drawer causing the drawer to jam or not close fully the seals seemto be in good order what can I do. regards Ern.
This is the common problem to everyone. Due to defrost failure. Check temp setting is not very low. Keep 5 degree.. Check thermostat, defrost timer are working properly. Now, manuyally press defrost switch or turn counter clockwise your thermostat. Then fridge shuts off and wait for sometimes to get complete defrost and then restart again by turning thermostat clockwise. Helpful?
Jan 30, 2011 | Refrigerators
I have samsung side by side. The fan behind the evaporator cover was making a grating noise and now doesn't seem to run and fridege not so cold. Took cover off and evaporator and fan completely iced up....
IT means that you have not fully defrosted the fridge in sometime.(should be done every 6 months max).switch it off,let it fully defrost for 12 hours,then restart,should work fine(i hope).
Nov 23, 2010 | Samsung Refrigerators
Fridge section of whirlpool fridge/freezer not working, compressor not running, freezer seems ok at the moment
Hello there:
I will post this in 2 separate post so you will be able to troubleshoot this fully ok?
f the refrigerator or freezer isn't cooling properly or if one is and the other isn't , you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: in next post
May 27, 2010 | Refrigerators
Freezer temp. 3 green lights flashing.
the flashing lights can be fixed by first turning the fridge off at the mains then turning both dials to economy ( this results in the fridge making a ..beeping sound). finally turning both dials fully in anti-clockwise to the off or zero position ( resulting in the fridge light bulb - going off).
Then lastly turning the dials back to our desired setting....(bulb light comes back on)
Now we only have the center green light on and NO FLASHING.
Jan 19, 2010 | Whirlpool Refrigerators
Eaton viking fridge needs to be colder
when you turn the knob anticlocwise it will be warmer and clockwise will be colder. some thermostat switches when you turn it anticlockwise untin it clicks turns off your fridge completely.
Sep 06, 2009 | Refrigerators
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
Viking Professional VCBB363SS Stainless Steel Refrigerator Logo
52 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
